Where Is The Gas Filter In Our Vehicles?
08.05.2020 20:33 # 1
yigit_dark
It's time for my car's oil maintenance. Prior to this, the vehicle was maintained at Opel special service with its familiar means. I buy the parts from the internet, I always bought a petrol filter. The master could not see the location of the gasoline filter, he said in the tank and did not handle it. He said no need. This time I want to change, I will go to a different master. Is it a long and troublesome job in the tank I was wondering or was it changing gas filters? Thanks
08.05.2020 20:33 # 2
No, teacher, you can see if you look carefully at the right rear wheel.
08.05.2020 20:33 # 3
acabuco
As the soner said the brain, I also changed, there is the right rear wheel right there.
08.05.2020 20:33 # 4
doganatak
https://forum.peugeotturkey.com/forum_posts.asp?tıd=9140
Maybe it helps in the same place already
doganatak 2017-09-14 17:25:41
08.05.2020 20:33 # 5
yigit_dark
[QUOTE = sonerkyl] no hodja, you can see if you look carefully at the right rear wheel. [/ QUOTE]
[QUOTE = acabuco] soner said the brain, as I said, in the past night, right rear wheel is there. [/ QUOTE]
Thank you so much. Opel could not find the car because it had a service. He looked under the vehicle on the lift. Then he called me and said "Look no, you don't understand." I even returned the gasoline filter.
08.05.2020 20:33 # 6
yigit_dark
[QUOTE = dogaatak] https://forum.peugeotturkey.com/forum_posts.asp?TID=9140
The subject content is very well explained. Thanks I have reviewed ..
08.05.2020 20:33 # 7
yigit_dark
I had the oil maintenance done today. Gasoline Filter has not changed again . The reason is that there is no master gasoline filter in your vehicle, he said. I went under it and examined it. There are 2 hoses coming out of the tank, one is the inlet and one is the outlet hose. He said it would be at the tip of it though. We followed the hose, really no filter. I couldn't analyze this job. Can I get your ideas.
08.05.2020 20:33 # 8
Did you take a photo of my brother, let's see here?
08.05.2020 20:33 # 9
yigit_dark
[QUOTE = sonerkyl] Did you take a bold photo, bro, let's see here. [/ QUOTE]
I remembered I left the master. I wish I would take it and upload it to the forum. If I can shoot tomorrow, I will try to lie under the car and shoot.
08.05.2020 20:33 # 10
ahmetdurna78
it can be there when you lift it under the right back seat. he does not want to change most of them because of laborious work
08.05.2020 20:33 # 11
yigit_dark
[QUOTE = ahmetdurna78] may be there when you lift it under the right back seat. he does not want to change most because it is laborious [/ QUOTE]
The master said he was in the buoy, but he is not changed. I don't know if it hangs out of the warehouse you bought but it's not in your car.
22.09.2022 17:55 # 12
dogut1
My 308 t7 1.6 thp vehicle suffering from the same issue, we could not find the location of the gas filter. The master said that it is in the tank, we need to lower the tank. He even said that it may be necessary to remove it until the exhaust, I did not do it. I'm really curious where you are.
23.09.2022 10:43 # 13
KILIC
Generally it is on the back right. If there is a black plastic piece under it when you lift the vehicle, it may be under it.
23.09.2022 10:48 # 14
KILIC
https:// www.youtube.com/watch?v=twAe9RB1nMk
Maybe it's in the same place have a look
23.09.2022 12:33 # 15
dogut1
No, sir, we looked under the seat, but I will remove the felt of the rear fender and I hope it is there.
