Where is the fan brain |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 19:37 | # 1 |
| 08.05.2020 19:37 | # 2 |
No need a brain for my brother to work, what is the problem when you say brain
| 08.05.2020 19:37 | # 3 |
Hello, are you asking the fan motor? As far as I know, the fan only works with the sensor. The sensors transmit the temperature to the brain. The other one is brown.It measures the brown temperature and turns the fan on and off.Green also increases the idling at low temperatures and facilitates the engine to warm up. |
| 08.05.2020 19:37 | # 4 |
The problem is solved. I found the fan brain, that is, the biteon brain in front of the crank, behind the left headlight, and all the roles and the sender circuits the fan controls. If the fan is ringing constantly or at the contact opening, the problem is that the water has taken water here. Thank you for your interest in everyone
| 08.05.2020 19:37 | # 5 |
kaan206 |
teacher, can we see, do you have a chance to take a photo?
| 06.11.2025 10:55 | # 6 |
Hello. Did you clean it or replace it? I have the same problem with the car I bought. It got noisy during the winter, I cleaned it, and then it went away again. Is there anyone selling original or similar quality parts? Or should I buy from a local dealer?
