Where is the 206 speed sensor
08.05.2020 21:09 # 1
Frt-Aydin
yes, my masters, does anyone know where the speed sensor is in 206?
08.05.2020 21:09 # 2
talip206
Well, my brother is not in a very troubled place. It is easier to reach the bottom by lifting the car. But when it grows up, the work is not over. As the screw is on the gearbox, it probably boils over time. They removed my speed sensor two skillfully in 3 hours. They managed to disassemble without breaking the heat and heat.
Let me describe the place as follows: When I open the bonnet, it is on the side of the engine compartment close to the glass. But not upstairs. It is necessary to insert the arm down.
08.05.2020 21:09 # 3
Frt-Aydin
Thank you, my aspiring master, I think I have a problem, I thought it would be useful to put it in and look at it, I said I couldn't do it myself.
08.05.2020 21:09 # 4
yusufmercan
No, teacher, you can't put it on yourself.
08.05.2020 21:09 # 5
Frt-Aydin
[QUOTE = yusufmercan] No, my teacher, you can't put it on yourself.
thank you
08.05.2020 21:09 # 6
Frt-Aydin
Is it possible for the masters to get the vehicle speed information from the speed sensor or abs sensor?
08.05.2020 21:09 # 7
My brother takes it from the speed sensor.
08.05.2020 21:09 # 8
Frt-Aydin
thank you soner thank you
08.05.2020 21:09 # 9
Frt-Aydin
[QUOTE = sonerkyl] is taking it from the speed sensor, brother. [/ QUOTE]
Brother did not have a speed sensor in my vehicle, said the master, I get the speed information from the abs sensor
08.05.2020 21:09 # 10
talip206
There are bro you can see if you look carefully. Remove the air cleaner hose. You see the look down socket at the bottom of the heating hoses that enter the inner cabin. On the gearbox.
08.05.2020 21:09 # 11
Frt-Aydin
wow friend insists on how difficult it is to come across a man who doesn't know the job.
08.05.2020 21:09 # 12
Frt-Aydin
[QUOTE = talip206] Are you bro you can see if you look carefully. Remove the air cleaner hose. You see the look down socket at the bottom of the heating hoses that enter the inner cabin. On top of the gearbox. [/ QUOTE]
I looked, I looked, I couldn't see
08.05.2020 21:09 # 13
talip206
You have to look at the Servisbox. When Google writes 206 speed mileage sensor, there are two types, one says gasoline 98 2002 compatible. The other says 2002 to 2009.
You can look at the compatible tools section in the link I provided.
talip206 2019-02-25 21:41:57
08.05.2020 21:09 # 14
Levent206xt
My 206 also gets the abs speed. No speed sensor, my car is automatic.
08.05.2020 21:09 # 15
Frt-Aydin
I guess it's not automatic
08.05.2020 21:09 # 16
maximusti
There is no speed sensor in the abs vehicle, I know that the vehicle gets its speed information from the abs sensor.
08.05.2020 21:09 # 17
talip206
[QUOTE = Frt-Aydin] is missing from the autos I guess [/ QUOTE]
Mine is automatic, but mine had it. We even disassembled and changed twice.
08.05.2020 21:09 # 18
Frt-Aydin
very interesting then, not on some models
