Where is the 206 petrol pressure relay
22.09.2021 09:44 # 1
Serbay17
Guys, where is the pressure relay? Gasoline does not go to the gas log, the car is running late, can you help me.
23.09.2021 21:23 # 2
talip206
Some 206s have a brown relay under the ecu.
In some, that relay is integrated into the motor fuse box (they call it the brain). It's a blue relay, but most masters say it will replace the entire brain rather than fix it.
If the gas pump is OK, check the fuses. Is it OK? If it is intact, have the engine fuse box checked.
