Where is the 206 horn?
08.05.2020 16:52 # 1
xpyhre
Greetings, my peugeot car's horn is not playing, I cannot look at the horn from the bottom because the car is flat on the ground. next to the wiper water tank? I would be glad if someone who knows cvp?
08.05.2020 16:52 # 2
metin
Hello there. It should be inside the bumper in front of the left front wheel. & Nbsp;
08.05.2020 16:52 # 3
Do you hear the sound when you press the horn in the form of a tick?
08.05.2020 16:52 # 4
xpyhre
[QUOTE = koliva] Do you hear the voice in the role when you press the horn? [/ QUOTE]
no I don't hear ..
08.05.2020 16:52 # 5
[QUOTE = xpyhre]
I don't hear no.
You should check the insurance as the first job. If the fuse is sound, it is probably caused by the steering wheel. The airbag part will be inserted and the conductive places of the cable behind it will be cleaned and retracted. Of course, this is not the way I described it, but there are a few puff spots. A detailed explanation would be on the forum.
koliva 2012-06-19 21:05:57
08.05.2020 16:52 # 6
EmSul
In our 206 GTI, the horn is in the front right, the front is in the right front of the front bumper, but the bumper is not replaced without disassembling. Instead, it is easier to install a new horn on the left front side. If it is broken, the horn is needed. If you do not hear the relay sound, the fuse or relay may have gone first. you should check
08.05.2020 16:52 # 7
xpyhre
[QUOTE = shumofnsb "emrah"] In our 206 GTI, the horn is right in the front of the front bumper right front of the drawbar, but you cannot replace the bumper without disassembling. If you do not hear, the fuse or relay may be gone, you should check them first. [/ QUOTE]
Where is the role? I found the insurance, the insurance is solid.
08.05.2020 16:52 # 8
EmSul
There are black relays in front of the fuse box, one of those relays is horn relay.
08.05.2020 16:52 # 9
xpyhre
When I press the horn, a faint sound comes from one of the black roles in the fuse box. But what is the reason for the horn not playing? There are two black roles. from one of the roles.
xpyhre 2012-06-19 22:37:01
08.05.2020 16:52 # 10
EmSul
Relay means that it works .. So there is a problem with its connections, horn or horn is broken ..
08.05.2020 16:52 # 11
[QUOTE = xpyhre] When I press the horn, a faint sound comes from one of the black roles in the fuse box. But what is the reason for the horn not playing? There are two black roles. from one of the roles.
When I first ask, I don't hear demistin "LOL"
As Emrah said, he works in the role, so keep it under control of the steering wheel, from BSI to role. It lags between the role and the horn. It is likely that either the horn is broken or there is a problem with its wiring. Reviews
08.05.2020 16:52 # 12
tigerland
Hi.
206 GTI horn; When you look from under the vehicle, you can chock your car in the lower right corner of the radiator and change it under. & nbsp; If you take a new horn, unplug it and plug in a new horn and try it, check the connection and fuse. ;
206_XS 2012-06-20 10:22:24
08.05.2020 16:52 # 13
EmSul
The horn electrician tried to change it under the vehicle, he couldn't do it without removing the bumper, then he put it on the left inner part of the bumper.
08.05.2020 16:52 # 14
xpyhre
I took the horn and lifted it with a jack, I pulled it from the front, the cable was unplugged. there is & nbsp; those grips are knocked, broken, the radio is now shaking gently, where can I find it? The picture below is available ... There are 2 plastic handles, we put these pointed irons here. Where do I find my satiliy in those plastic handles? its name is in the form of the foot of the radiator bushing. & nbsp;
& nbsp; track number 3 ...
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp ; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp;
xpyhre 2012-06-20 18:12:06
08.05.2020 16:52 # 15
The reference number is written in the picture you sent. You can obtain it from any authorized service center with the number 1312.99. As soon as the radiator is already in place like a stone, it shakes slightly. He will swing a little bit after tactic.
08.05.2020 16:52 # 16
xpyhre
do you think it doesn't matter much koliva? Something was shaking, already with those grips. But the radiator is pulling upwards .. will it make a sound when the car is running? xpyhre 2012-06-20 20:06:56
