Where is Horn Relay?
08.05.2020 20:23 # 1
doganatak
I ordered ferrari horn today and tomorrow the next day will come. I would like to attach a vibrating horn relay to this horn. But where could I not find the horn relay (do you have it?). I want to get the horn relay that vibrates when buying a relay for the fog to install fog. doganatak 2017-06-05 16:07:42
08.05.2020 20:23 # 2
sdttn
In the fuse box in the engine compartment.
08.05.2020 20:23 # 3
doganatak
[QUOTE = sdttn] In the fuse box in the engine section. [/ QUOTE]
Somewhere in the bottom of this?
08.05.2020 20:23 # 4
Popomundo
You can not interfere with horn roles, you can do what you want to do from the horn exit, but ...
08.05.2020 20:23 # 5
doganatak
[QUOTE = Popomundo] You cannot interfere with the horn role, you can do what you want to do from the horn exit, but ... [/ QUOTE]
If I have a different relay connected, no problem Thumbs Up
08.05.2020 20:23 # 6
Popomundo
Normally, you can connect the horn to the trembling role with the plus tip.
08.05.2020 20:23 # 7
doganatak
[QUOTE = Popomundo] normally you can connect to the horn plus tip trembling role, no problem .. [/ QUOTE]
Thanks now let's wait for the horn to arrive
08.05.2020 20:23 # 8
Popomundo
I think you cannot get an efficiency from the ferrari horn with the flickering role, because I think that the ferrari horn will not be able to steal the horn, which will give the electricity intermittently to a vibrating role.
08.05.2020 20:23 # 9
doganatak
[QUOTE = Popomundo] I don't think you can get an efficiency from the ferrari horn with the flickering role, because I think that the ferrari horn will not be able to ring the horn, which will give the electricity a choppy role to the vibrating role ... [/ QUOTE]
Somehow, the relay is not expensive.
08.05.2020 20:23 # 10
Popomundo
Do you know how to connect exactly?
08.05.2020 20:23 # 11
doganatak
[QUOTE = Popomundo] Do you know how to connect exactly? [/ QUOTE]
I saw it on google and youtube. If there is a scheme you know, I can get it. I am inclined to this kind of work
08.05.2020 20:23 # 12
Popomundo
You connect the + end to the original horn of the vehicle, ie the non-yellow green cable to the 86 end of the role, to the 85 end of the role - you connect the 30 or the ferrari horn directly to the end of the relay and connect the ferrari horn to the end of 87, of course, you connect a 15 amp fuse between the 87 end and the horn, and the minus you connect the chassis of the horn to the relay. You can attach the yellow green cable, which is the end ...
08.05.2020 20:23 # 13
doganatak
[QUOTE = Popomundo] You connect the + end to the original horn of the vehicle, that is, the non-yellow wire, to the 85 end of the role at the 85 end - you connect the ferrari horn to the end of 87 and connect the 15 amp fuse between the 87 end and the horn, You can also attach the yellow green cable, which is the negative end of which you connect the chassis to the role ... [/ QUOTE]
Thank you when I connect with the vibrating relay, I will write the result good or bad. I want to ask one more thing. If I don't wear a vibrating relay, can I use it by tying the pole ends instead of the old horn. Besides, it gives a relay next to the horn I bought, it says the sound amplifier relay, what is it?
08.05.2020 20:23 # 14
Popomundo
It would be better if you plug it in front of the role in the fuse box, as soon as you load the role, the external role is broken, you give 10 TL and change it.
08.05.2020 20:23 # 15
doganatak
[QUOTE = Popomundo] It would be better if you put it on the front, as soon as the role in the fuse box is impaired, you will break the role on the outside, you will give 10 TL and change it. You will not have any problems ... [/ QUOTE]
Thanks for the valuable information, the job is only for the horn.
08.05.2020 20:23 # 16
Popomundo
You're welcome
08.05.2020 20:23 # 17
doganatak
I looked at the horn when I removed the bumper to install fog on Sunday.
08.05.2020 20:23 # 18
Popomundo
just like yellow green minus teacher
