Where is 206 xs Catalyst
08.05.2020 20:05 # 1
prdxy
Friends, I don't quite understand, I didn't know if there is a catalyst in my vehicle, where exactly is this piece, where to look visually, under the vehicle or in the engine compartment? thanks.
08.05.2020 20:05 # 2
in the engine department. Where I marked
08.05.2020 20:05 # 3
prdxy
Do you have a teacher?
prdxy 2016-12-17 16:51:25
08.05.2020 20:05 # 4
Your engine looks 1.4, and the engine picture I added is 1.6 times not visible for your vehicle.
08.05.2020 20:05 # 5
hzr206
Could the owner before you cancel the catalyst? There seems to be a straight pipe in photos.
08.05.2020 20:05 # 6
prdxy
Could the 1999 model be 1.6 xs at the bottom, the straight pipe looks pretty original?
08.05.2020 20:05 # 7
prdxy
08.05.2020 20:05 # 8
ALLEX
The floor has been canceled.
The experienced person who does the job is obvious, but the resources are not machine fabricated, this is obviously handmade.
Exhaust emission already gives the exact result.
08.05.2020 20:05 # 9
prdxy
Does the vehicle pass the inspection in this way
08.05.2020 20:05 # 10
ALLEX
[QUOTE = prdxy] Does the tool go through the inspection in this way [/ QUOTE]
Cover the exhaust pipes with insulating material.
Remove the exhaust emission washer outside from a special location.
Choose the last muffler from the silent ones and go to the examination.
If you do the engine cleaning and leave, think that the people at the inspection station do not behave biased.
08.05.2020 20:05 # 11
prdxy
@allex exhaust does not produce a loaded sound. Only when loaded on excess gas, the sound comes out of the air filter kit performance filter chamber
Now let me ask if it passes with this air filter.
Would it be useful if I had a universal catalyst?
When the vehicle is running, there is a lot of white smoke coming out of the exhaust when the engine is cold and there is an excessive smoke output.
08.05.2020 20:05 # 12
hzr206
[QUOTE = prdxy] @allex there is no sound loaded from the exhaust. Only when loaded on excess gas, the sound comes out of the air filter kit performance filter chamber
There should be no problem with the air filter, but when catalyst is canceled, vehicles often throw out extra smoke.
08.05.2020 20:05 # 13
prdxy
Do you have a universal catalyst recommendation?
08.05.2020 20:05 # 14
hzr206
http://www.egzoz.com.tr/universal-katalizorler,la_208-2.html#labels=208-2&stockonly=0&type=catalog&searchalpha=&searchprice=asc&tp=
You can look at this site.
08.05.2020 20:05 # 15
prdxy
So there are a lot of them here. Are they all compatible?
