Where does this socket belong?
08.05.2020 18:55 # 1
dahi
Hello friends, I saw an idle socket while checking the right side of the engine today, but I could not find the part to be installed where do you think this socket belongs.
Vehicle 307 1.4 HDi
08.05.2020 18:55 # 2
dahi
The back is dark, and its clear picture
even 2014-12-06 20:54:09
08.05.2020 18:55 # 3
Ahmet_ach
as if it belongs to the headlight engine
08.05.2020 18:55 # 4
dahi
[QUOTE = Ahmet_ach] as if it belongs to the headlight engine
I checked that the headlight cable length is not short there.
08.05.2020 18:55 # 5
ysndrsn
I think it would be stupid to see if your headlights hurt your headlights and check that they are not flashing and may be stuck short.
08.05.2020 18:55 # 6
seydisehirli
Could it be the oxygen sensor?
08.05.2020 18:55 # 7
dahi
Can [QUOTE = seydişehirli] have an oxygen sensor? [/ QUOTE]
I know the vehicle doesn't have a diesel oxygen sensor, sir. I asked the master's master, the room could not know.
08.05.2020 18:55 # 8
seydisehirli
I couldn't determine the exact location of the brother, but I know I have to tell you that I had you in my vehicle, so a second socket was made for a socket charger, so I wonder if it could be later.
08.05.2020 18:55 # 9
riderzist
[QUOTE = genius] Hello friends, while checking the right side of the motor today, I saw an idle socket, but I could not find the part to be installed where do you think this socket belongs.
Vehicle 307 1.4 HDi
I have it too. 307xt 1.6 gasoline
08.05.2020 18:55 # 10
dahi
On some issues, I saw a socket socket similar to this, says that it belongs to the filter, some says that it is set to get extra power for illumination, if my path passes by the industry, I will especially ask the master and reply you.
08.05.2020 18:55 # 11
madblueblacksea
I know there are 4 wires with 2 wires in the back of the engine. 1.fuel heater 2.water sensor (both connected to the diesel filter) 3. reverse gear master 4.EGR valve. Headlight motors are usually 3 wires
08.05.2020 18:55 # 12
riderzist
Even if that side's headlight engine is running, if you check and write it. The headlight motor on the side of that socket is not working on me. same socket
08.05.2020 18:55 # 13
dahi
@rizerzist control. I have worked on both sides, no problem.
I have removed the battery because it belongs to the diesel filter.
If it's plugged in where I can't see it, I don't know it.
http://imageshack.com/a/img661/8683/w8s9oy.jpg
As I know, I did not tamper with it, and if you deal with the death, I gathered it so that it does not return to it.
08.05.2020 18:55 # 14
riderzist
[QUOTE = genius] @rizerzist control. I have worked on both sides, no problem.
As I know, I did not tamper with it, and if you deal with the death, I gathered it so that it does not return to it. [/ QUOTE]
you did just as well. In a way, when you go to something, you ask the electrician. I could not stand it, now I went, I asked him to connect the LPG to the computer, it is in my socket, but it looks very similar to me. I looked at there any other sockets to see if there was any other socket ...
Friends with diesel i can give information to their vehicles if they look at it.
08.05.2020 18:55 # 15
riderzist
In the meantime, since the headlight engine is gone, it cannot be repaired, either we will either wear it or replace the headlights.
08.05.2020 18:55 # 16
dahi
[QUOTE = riderzist] [QUOTE = genius] @rizerzist control. I have worked on both sides, no problem.
It seems to me that if the sockets are similar, it might not be what your master said, well, someone who knows will probably ((:
08.05.2020 18:55 # 17
riderzist
[QUOTE = genius] [QUOTE = riderzist] [QUOTE = genius] @ rizerzist control. I have worked on both sides, no problem.
It seems to me that if the sockets are similar, it may not be what the master said, well, someone who knows will probably come out (: [/ QUOTE]
no no :) I got the confirmation, I said go to the atiker and change the lpg filter, let me ask him, he even connected it to the computer. A friend who has a diesel can tell where he is, but it is best to go and ask the electrician.
08.05.2020 18:55 # 18
madblueblacksea
Plug of the diesel heater, teacher. The cables must be thicker than the others. When I bought the car, I was not plugged in mine. The integrity of the filter change
08.05.2020 18:55 # 19
madblueblacksea
I flipped the picture, but I'm sorry, but it's wrong. The location of the filter in the lower back
08.05.2020 18:55 # 20
riderzist
[QUOTE = madblueblackse A]
Thank you very much, it is necessary to stand at the head of the masters, I always wait at the beginning, look at the dismounted parts.
Page : / 2
