Where does the oil leak in the picture come from |
| 08.05.2020 19:22 | # 1 |
Why would this happen? Do I ever have friends or people with oil leakage problems from the same point? ![]() |
| 08.05.2020 19:22 | # 2 |
It may be missing from the top cover gasket, so it is not a very urgent case, if you have to, you can continue to ride by checking the oil, but at the first opportunity, the cost of the book is not much because it should be set well because the engine will cool down. |
| 08.05.2020 19:22 | # 3 |
but isn't the top cover gasket a little higher? further down and in the corner. that's exactly the timing belt cover.
| 08.05.2020 19:22 | # 4 |
sonerkyl |
yes, it may have leaked above, if the photo is closer, it can be said more clearly.
| 08.05.2020 19:22 | # 5 |
99% of the 1.4 gasoline engines are leaking from there, I think it's the fabrication error.
| 08.05.2020 19:22 | # 6 |
okan77 |
There should be no oil leakage to the timing gears.
| 08.05.2020 19:22 | # 7 |
I had the problem of oil leakage from the same point. For years, depending on the lpg usage, half the mator was opened, which had to refute the cylinder head gasket. By the way, if the timing belt has absorbed the oil, its life is shortened by half. |
| 08.05.2020 19:22 | # 8 |
[QUOTE = fluoxytil] I had the problem of oil leakage from the same point. For years, depending on the use of lpg, half a mator had been opened, which had to refute the cylinder head gasket. By the way, if the timing belt has absorbed the oil, its life is shortened by half. [/ QUOTE] Yes brothers; The cylinder head gasket was ... The LPG plug-in has just been 2 months, and this oil incontinence started after that. the approximate cost was around 500-600. Pretty much oil is missing. I will follow it and put it as the oil decreases.
| 08.05.2020 19:22 | # 9 |
He is running out of the top cover gasket. Look at it as soon as possible.
