where do you think this water comes from
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:12 # 1
gngburak
Greetings to everyone
the car remained under the rain for 1 day, did not move
the next day I looked at the bidet side of the driver 5-6cm up water accumulated
I looked around I could not find where to enter.
If there are friends with the same problem, could you solve the problem.
& nbsp;
08.05.2020 17:12 # 2
Bugra
There was a friend who had a new problem. I think it was getting through the clips of these door slats. of course if you want to control the door wick and the glass wick
08.05.2020 17:12 # 3
Bugra
http://forum.peugeotturkey.com/forum_posts.asp?tıd=25948
08.05.2020 17:12 # 4
gngburak
I checked all of them. I even checked the antenna connection and still couldn't find it.
08.05.2020 17:12 # 5
Bugra
Then, after draining the water inside the vehicle, go to a car wash and experiment with pressurized water while inside. Then I guess that it is understandable by seeing where the water enters.
08.05.2020 17:12 # 6
mev347
I shared it before. the side of the vehicle can enter the side of the slat between them.
08.05.2020 17:12 # 7
gngburak
[QUOTE = mev347] I shared it before. the side of the vehicle can enter the side of the slat between them. [/ QUOTE] I looked at all of them, I removed the inside of the doors, there was no wetness, there was only a binder, there was a wetness next to the gas pedal, there was a wetness in the biyeror.
08.05.2020 17:12 # 8
mev347
from my strict laths or glass roving. I'm very busy nowadays. I got into the car yesterday, the side of the side seat was in the water. 2012-12-10 17:02:02
08.05.2020 17:12 # 9
gngburak
exactly, it must be done as soon as possible.
08.05.2020 17:12 # 10
mabolla
My teacher did not change the glass? They could not sit after changing the windshield, the water was on the driver's side, we had to remove the glass and paste it again.
08.05.2020 17:12 # 11
ozgur307
the speaker to the door-electrical cable protector is displaced, but it can receive water & nbsp;
08.05.2020 17:12 # 12
gngburak
[QUOTE = liberal307] door-to-door speaker-electric cable protector is dislodged, but can also get water & nbsp;
where exactly is it & nbsp; where is free
may be where I think
has a plastic pressed in place where it rests its left foot I wonder if there is
08.05.2020 17:12 # 13
gngburak
there is a green thing on a black plastic piece in the upper left corner of the picture
me there
08.05.2020 17:12 # 14
sezar206
Check the heater core. If there is a decrease in the water of the vehicle, the honeycomb has definitely exploded.
08.05.2020 17:12 # 15
ozgur307
it does not appear in the picture, when you open the door where the speaker cables pass. at left knee. & nbsp;
08.05.2020 17:12 # 16
extremex16
If the vehicle is a sanroof or a teacher, if it is a sonof, it enters & nbsp; it opens its holes.
08.05.2020 17:12 # 17
extremex16
Or the water accumulating inside the door sill is entering. Take a look at the part of the door sill that corresponds to the door sill. Water leaking from the door glass should flow from the door expense.
08.05.2020 17:12 # 18
Serkan
[QUOTE = extremex16] if your car is a sanroof, if my sonroof is & nbsp; it will open the holes. [/ QUOTE]
the same thing happened in scenic, sonroof expenses included clogged water, we opened the expenses with compressed air problem solved
08.05.2020 17:12 # 19
extremex16
[QUOTE = Serco05] [QUOTE = extremex16] if the car is a sanroof, my teacher opens the holes if he is a sonofo. [/ QUOTE]
the same thing happened in scenic, sonroof expenses included clogged water, we opened the expenses with compressed air.
08.05.2020 17:12 # 20
kaan__
friends who have difficulties in this regard think that it is a result of the blockage of the body or water drain in the first place, but ... just because it is the driver's side, the source of the problem is your heater radiator hole ... hopefully you can find a master that will come out from the side of the gas pedal ..
otherwise The chest can be said to be removed ...
It may be interesting to accumulate 5-6 cm of water, but you may have noticed that the water leaking from the heater may not have been drained because it has no place to discharge ...
kaan__ 2012-12-10 23:34:56
Page : / 2
