Where can I get the cable from the battery.
08.05.2020 17:18 # 1
EnSoNiQ
Hello friends, I will install the sound system that I removed in my old car, but in 307, can anyone throw a cable from the battery to the picture with a picture? & Nbsp;
08.05.2020 17:18 # 2
impact
I might have thought very simple, but wouldn't it have been taken from under the lighter?
08.05.2020 17:18 # 3
gozem
You pull the plug of the hood opening wire from there and take it inside, but you should close it with silicone because it doesn't fit instead of repeating. In rainy weather, the water, which overflows from the discharge holes after the rain, flows from there to the vehicle's BSI.
08.05.2020 17:18 # 4
106fb
I searched for that place too. There is a place under the wiper, which is covered with plastic stopper, where you can remove the black grille and see it. There are two places. remember, otherwise water will fill up.
08.05.2020 17:18 # 5
EnSoNiQ
thank you for your help:) & nbsp;
08.05.2020 17:18 # 6
istanbullu_3886
There is only one crossing point in kaedes 307, there is a rubber casing in the back of the left door, which binds to the brain of the other cables. Take it out to the fender.
