When you release the accelerator pedal, the vehicle collapses forward
18.06.2021 23:31 # 1
Meerrtt
I am a user of lpg+benzin 2001 manual 206.
I'm asking because I don't know. I do not know what is the truth, but it seems abnormal to me.
1. I take off in gear, when I release the gas between 2000-3000 rpm, the vehicle seems to collapse into one, it's as if you have stepped on the brake, it's the same, there is engine brake, but I have never seen such severe engine braking in any vehicle, I wonder if it's a problem. It does the same in 2nd gear and does the same at 3rd. Not as much as 1st gear and 2nd gear. When I press the gas a little bit, it sticks to the seat, then it sticks to the steering wheel, I press it millimeters, but it doesn't help. Do you think this is a problem? I would appreciate if you share your valuable ideas, thank you in advance.
25.06.2021 23:23 # 2
Black lucky
I am having the same problem. Even if I release the gas a little bit, it throws forward and cuts speed as if I have stepped on the brake. By the way, my car is 206 xline 2001. Can you help me if there are friends who know what could be causing the problem?
02.07.2021 22:56 # 3
hhozturk
Is the car slowing down by shaking?
14.07.2021 12:34 # 4
jamiaz
When I release the diesel 1.4 gas, the vehicle slumps forward a little as if the brake is applied.
08.08.2021 00:07 # 5
Meerrtt
Sir, I understood that this is not a problem, since the first gear gear is a large gear, its torque is very high. When going downhill with 1st gear, it does not go down as fast as other gears. Engine braking is high. When you give the gas to the vehicle, when you leave it as you age, the engine brake pushes forward as a reaction force. Take your foot off the gas in 1st gear, millimeter by millimeter. You will feel this less.
