When Water Sees Failure.
08.05.2020 16:26 # 1
yalcin34
Vehicle 206 1.4 Colorline 2001: after my water passes a problem with my model car and the engine malfunction lamp is on the display, the brain was burned in the previous `` new engine brain was installed on the roads. I got into the water again and after 1 day the engine malfunction lamp came on again, what is the reason? I have a piece that touches Su?
08.05.2020 16:26 # 2
djchaos
make sure that there is no place to take open water while the brain is inserted, guess the water is touching the brain, the malfunction lamp may be on the sensors Connect to the computer, find out what the malfunction is and make sure that the newly installed brain is installed in a way that does not absorb water.
08.05.2020 16:26 # 3
Ucyuzalti
There is an oxygen related sensor or check the value of the gases coming out of the exhaust, water may be coming to it & nbsp;
08.05.2020 16:26 # 4
fatihkiziroglu
There is a brain called BSI brain. When it enters the water, it is getting water.
