When the throttle is pressed to the throttle lever.
08.05.2020 18:00 # 1
good evening everyone.
I have 207 vehicles. 37,000 km is now.
Something has caught my eye for the past few days. Maybe it was already, but I did not notice. maybe I don't know anything normal.
When I put the car in 1st gear, I lift my foot from the clutch and move slowly while the gear lever slips backwards.
is this normal?
08.05.2020 18:00 # 2
eren106
check the lower engine mounting may be broken
08.05.2020 18:00 # 3
[QUOTE = eren106] lower motor ear may be broken check [/ QUOTE]
I do not think so.
If the lower engine ear breaks, the engine shakes. When I open the hood, the engine runs smoothly and without shaking.
While using, it also knocks in gear shifts.
08.05.2020 18:00 # 4
kuscu38
look at the flows ... there is a problem in the flow of tulip or flow balls ... it does not work, but when it starts to move, it starts to move back and forth over time, it starts to yaw the vehicle while going ...
08.05.2020 18:00 # 5
error
Hodja may not be felt at idle when the engine's ear is broken, but when you start or stop the engine, you will see a shock in the engine.
08.05.2020 18:00 # 6
[QUOTE = errör] My engine may not feel shaking at idle when the engine's ear is broken, but you will see a shock in the engine when I start or stop the engine ... [/ QUOTE]
friends, there is no jolt, thank God.
I know well from my old car that the malfunction of the engine ears is the cause. was knocking on the gas loading and dropping.
My subject sounded a little twisted. Not a motor ear failure.
When I got up slightly when I put it into 1st gear, I asked if it is normal for the gear to flex 3-5mm rearward.
maverick 2013-10-23 00:15:18
08.05.2020 18:00 # 7
error
millimeter is normal, I have it in me: D
08.05.2020 18:00 # 8
xMEGANx
I have it, it's normal, brother, no abnormal situation :)
08.05.2020 18:00 # 9
serkans
I have normal norm
