When the Peugeot 206 gets gas, it's like it's running and don't stop
17.05.2022 00:29 # 1
Gurkan Alp
my car is 206 x desing 2006 1.4 petrol no lpg
When I get 206 petrol it seems to start and stops. When I press the gas and start it, there is no problem
When the engine is cold, it only takes on a mars. If I stop before the engine reaches 90, it seems like it's running bad
it seems like 8 to 6 idle when it idles and stops at the lights
throttle changed and all maintenance done
brake servo checked.
I suspect crank sensor or temperature sensor
17.05.2022 11:49 # 2
So, have you looked at the fuel pump? This can happen because the pump does not provide enough pressure when it heats up. manifold gaskets etc. Have it checked, the vehicle may be getting air from somewhere.
17.05.2022 23:06 # 3
Gurkan Alp
pump was checked in good condition,
there is no room for air, but opet devastated me. now I'm going to run out of half a tank of gasoline and test it
I bought it from opet. I normally buy shell or total gasoline. for some reason
17.05.2022 23:07 # 4
Gurkan Alp
I'll post the result, thanks again
15.07.2022 21:54 # 5
Gurkan Alp
greetings wrüth petrol additive and petrol from shell problem solved, only mars is available and idle fluctuation is up. I wanted to share in case anyone comes to the press
thanks
12.03.2023 23:11 # 6
Gurkan Alp
hello, the problem persists. I changed the injector recently. I also changed the
carbon canister valve. After a lot of research
and when I wasted the revs dropped and my working on the first mars got better.
for the information of anyone who comes to the press
