|   | When the horn is pressed, the headlight turns off and the air conditioner sushi for 1 second. |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Peugeot Commercial Class | |
| 03.07.2020 00:53 | # 1 |
|  Fazli053 | |
| 03.07.2020 08:44 | # 2 |
|  sonerkyl | |
First of all, welcome to us. The problem seems to be with the headlight signal lever. there is a short circuit. Are you the first owner of the vehicle? Does the vehicle warranty continue? Is the air conditioner manual or digital
| 04.07.2020 01:17 | # 3 |
|  MaDWisH | |
If you have an automatic headlight sensor, it may be caused by a short circuit. If you turn on the headlight manually, you will solve the problem or you need to overhaul or change the headlight lever.
| 07.07.2020 00:06 | # 4 |
|  Fazli053 | |
There was no change, I changed the horn, it was straightened last time I looked at the signal arm, but guys, why is the air conditioner silent?
