When the engine is cold
08.05.2020 21:10 # 1
Bobin06
peugeot 308 1.6 vti 120 my first start (engine cold) wait for two minutes then move I shake the car and stop when it is idle or in gear (low speed) why is there any problem?
08.05.2020 21:10 # 2
x571
Is there a malfunction code. Does it do when the weather is cold, rainy or damp. Does the engine run during the day when it gets hot. Is there a tremendous tremor? Did you listen to the exhaust during the trembling, how is the sound coming from?
08.05.2020 21:10 # 3
shaq1907
[QUOTE = Coil06] peugeot 308 1.6 vti 120 first start (engine cold) I wait for two minutes, then I move, I shake the car and wonder why it stops when it is idle or in gear (low speed). I am waiting for your help. [/ QUOTE]
Did you solve the problem? If solved, can you write how you did it?
08.05.2020 21:10 # 4
Do you have LPG in the vehicle, hodja? first look at the malfunction codes. generally it is made of misfire spark plug - coil and solenoid valve.
08.05.2020 21:10 # 5
Bobin06
There is LPG, there is no problem in LPG.
