When the air conditioner is turned on, the sound coming from the wheel |
| 08.05.2020 17:43 | # 1 |
| 08.05.2020 17:43 | # 2 |
First of all, the air conditioner is open, the vehicle is weak on departures, this is not a problem, but I cannot say anything about the sound event ...
| 08.05.2020 17:43 | # 3 |
[QUOTE = errör] firstly the air conditioner is open, the vehicle is weak on departures, this is not a problem, but I can not say anything to the sound event ... [/ QUOTE] |
| 08.05.2020 17:43 | # 4 |
Well, my guess is in the following direction. The sound comes from the v-belt. You know, the 307s are powered by electric power. Also, when the air conditioner that takes energy from the v-belt is added, v-belt may be forced. |
| 08.05.2020 17:43 | # 5 |
If I think that if it sounds like a crackling sound in a full turn while turning to the left, I couldn't remember what the axles are, or what it is called, it is broken. You have to replace it with the original part or the original part .. |
| 08.05.2020 17:43 | # 6 |
If the axle head is broken, it makes sound at every turn. It doesn't matter whether the air conditioner is open or closed. |
| 08.05.2020 17:43 | # 7 |
Since the axle pressure begins to deteriorate, the vehicle is doing so hard in rotations, after a few km it will deteriorate and will always start to do. |
| 08.05.2020 17:43 | # 8 |
[QUOTE = laedri] Well, my guess is in the following direction. The sound comes from the v-belt again. You know, the 307s are powered by electric power. Also, when the air conditioner that takes energy from the v-belt is added to it, the v-belt may be forced. [/ QUOTE] Maybe I was thinking in this way in the first plan, but when turning to the right, there is no gram sound, even to the right I do not hear any sound. In this case, is it not necessary to sound when it rests to the right?
| 08.05.2020 17:43 | # 9 |
[QUOTE = laedri] If the axle head is broken, it makes sound in every turn. It doesn't matter whether the air conditioner is on or off. It also knocks in the form of plug and play. DIV> If the axle head is broken, when I turn it to the left, the air conditioner is off and it doesn't knock and push back. I think this way ..
| 08.05.2020 17:43 | # 10 |
Could there be sound from the air conditioning fan or friends? There was a gaart-like sound like a friction sound coming in. The sound showed, I noticed the sound, I opened the hood, sat on it, tried to understand exactly where it came from when the sound came out & nbsp; but it could not solve the room. I'm surprised what I'm going to do ..
| 08.05.2020 17:43 | # 11 |
cocomo |
[QUOTE = laedri] Well, my guess is in the following direction. The sound comes from the v-belt again. You know, the 307s are powered by electric power. Also, when the air conditioner that takes energy from the v-belt is added, v-belt may be forced. [/ QUOTE] the most logical comment b was div>
| 08.05.2020 17:43 | # 12 |
[QUOTE = cocomo] [QUOTE = laedri] Well, my guess is in the following direction. The sound comes from the v-belt. You know, the 307s are electrically powered. Also, when the air conditioner that takes energy from the v-belt is added, v-belt may be forced. [/ QUOTE] the most logical comment That's it [/ QUOTE] So why is this sound only when turning left. It doesn't show up on my right turns DIV>
