Since I bought the car, my air conditioner was fine. I recently asked him to check the air conditioner with my friend. He said that the gas was too low and he made the addition. We run the air conditioner, it seems to me that it cools better. It took us about 2 months to add this gas. In the meantime, when I run a few, there was no problem. But today, I activated the air conditioner, but the air conditioner was turned off spontaneously before it was cool enough. I tried again the same thing again. I press the button click compressor is running. clicks compressor without blowing cooler. and at this moment my fans aren't working. my fans do not come into operation when the fans normally have to run when pressed. The fans start up around 100 degrees for the motor cooling in the air of the air conditioner. However, when this air conditioner suffered, the fans did not work during the cooling of the engine when the fans did not work. the heat was 110. I stopped immediately I stopped. I pulled the pole press, plugged etc. fans started to cool the engine. we were going to be hot. I came to my mind that first of all 3 roles in the middle of the fans would be a problem. I wanted to consult with the & nbsp; masters before hand. Are there any ideas or a similar situation?
   cecoli   2010-04-16 16:35:26
