When should idling be?
08.05.2020 21:22 # 1
littlenikksay
Hello my car 206 1.6 100 petrol + LPG
After the vehicle warms up, the idle is just above the 3rd line, like 750rpm and the vehicle is shaking
Is it low in my car, I wonder if the idling is normal.
08.05.2020 21:22 # 2
It should be around 800-850 cycles. this may be caused by the active throttle air filter. an air hose or filter cap that doesn't fit well is also effective. Do you have this problem with gasoline. if not, it may be caused by the lpg setting.
08.05.2020 21:22 # 3
littlenikksay
The air filter has just changed, but the throttle was disassembled to clean it once, but no adaptation was made.
08.05.2020 21:22 # 4
omerb
I know that throttle adaptation is done when a new throttle is installed or if there is a problem with the spring or motor assembly on the valve. Of course, if disassembled according to the procedure.
The battery pole head is removed when it goes out without removing the throttle. Depending on the model, it is expected for 5-10 minutes. Throttle ecu communication is interrupted. Then cleaning is done.
When the vehicle is at idle, there is an idler engine that transmits air from the front of the throttle to the manifold. Ecu sends commands to the idling engine according to the summer or winter event or according to the air conditioning on / off event. It also opens and closes.
Imbalance can also be due to this. I can say that it is useful to have him cleaned.
Because like a stopper, it opens and closes the airflow hole. (idle engine is not used on some models)
omerb 2019-11-26 19:35:33
08.05.2020 21:22 # 5
littlenikksay
Can we upgrade idle manually?
08.05.2020 21:22 # 6
[QUOTE = littlenikksay] Can we upgrade idle manually?
My teacher does this automatically on most of the 2000 model vehicles. As far as I know, the throttle has no adjustment in electronic ones.
08.05.2020 21:22 # 7
littlenikksay
So how do we fix this idle?
