when shifting
08.05.2020 16:21 # 1
volkan26
when your friends shift into gear, the car is geared but it does not go back what is the reason tskler already
08.05.2020 16:21 # 2
To Open an Introductory Topic Please
Click This Link: http://forum.peugeotturkey.com/new_topic_form. asp? FID = 22
1.- Your name, surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear about the site:
7.- Your Blood Group:
8.- Your zodiac sign:
9.- The team you support:
10. - Which county or province are you:
11.- Your MSN address:
do this we will help you more easily if you fill in and open a topic.
Thank you.
08.05.2020 16:21 # 3
[QUOTE = volkan26] when the gear shifts back, the car is geared, but it doesn't go back. I wonder why tskler [/ QUOTE]
this trouble will be the gearbox.
08.05.2020 16:21 # 4
volkan26
Well when it passes again it gets better
08.05.2020 16:21 # 5
This corresponds to the second topic I mentioned. Does your car shake on departure? Or is it difficult to get into 1st gear? & nbsp;
if they are not available, raise the clutch adjustment a little.
08.05.2020 16:21 # 6
volkan26
1.n gear is sometimes hard to pass on my second try
08.05.2020 16:21 # 7
[QUOTE = volkan26] 1.n gear is sometimes hard to pass on my second try properly [/ QUOTE]
if first and back If it gets harder when it shifts into gear, this pressure indicates that the pad has completed its lifetime.
08.05.2020 16:21 # 8
mehmet eren
Check the transmission and gearbox.
08.05.2020 16:21 # 9
taksicicocuk
the master is not afraid, only the pressure inside the transmission is finished & nbsp;
08.05.2020 16:21 # 10
volkan26
I will look at you right now.
08.05.2020 16:21 # 11
I think that the press start is over, I know from my father's car, the car has become 101.000 km, the pressure has not changed the pad, the car is going to both first and reverse gear, it is passing for the second time. I don't know how long it will last. "Embarrassed" says to my father where he goes & nbsp; "Laugh"
08.05.2020 16:21 # 12
taksicicocuk
cuddle yourself & nbsp;
08.05.2020 16:21 # 13
Ucyuzalti
For easy reverse, try shifting first into gear then back to back :)
08.05.2020 16:21 # 14
volkan26
I added to the introduction section if you have something you can introduce.
08.05.2020 16:21 # 15
ByHack
friends, yes, when the pressure pad is finished, this problem is encountered, but it is not just a print-related event. There is a bole case with 307 petrol manual transmissions. especially when reversing. If you use a truck or tractor, you know, you need to renew the clutch just like their gear :) When the gear does not pass, lift your foot from the clutch and then press it again. I don't necessarily say that the pressure is not 1 month. It is not a very common situation, but it does it occasionally. By the way, when the gear is not fully passed, that is, when the gear sounds, do not force the gear again without pressing the clutch.
08.05.2020 16:21 # 16
Ucyuzalti
The same problem is sometimes the best way my 306 is doing, as I wrote, I discovered & nbsp; "Grin" 1 gear throwing your foot off the clutch, throwing it back you never carting & nbsp; "Applause"
08.05.2020 16:21 # 17
hasanyilmaz
I have the same problem, I can not put it back into gear three or four times, sometimes a friend mentioned a plastic piece, it was an inexpensive piece of work, I think I would change it.
08.05.2020 16:21 # 18
Kemanyak
The problem of all pugs has nothing to do with this pressure pad :) If you press the clutch twice or plug it in 1 and try again, you will see that it passes easily. No problem :)
08.05.2020 16:21 # 19
volkan26
now I have learned that, as soon as the friends press the clutch, do not shift into reverse, wait a 5 10 seconds, then our master said, then it was fixed in the same way, press the gear clutch when the idle was just as it said, wait for 5 seconds.
