When Running the Vehicle in the Morning ..?
08.05.2020 16:13 # 1
oguz6578
I have the problem of stopping my 307 sw petrol + lpg when I start my car in the morning, but it only happens when the engine is cold at the first start ..... And when I start it is a misfire in the car when it is cold, it takes a little 10 seconds as if the engine will stop as if it was cold I know what he pulls out by force, he kicks in the first 10 seconds, then it gets better ... >
And the bidet is now tired of the sounds coming from under the vehicle: ((((((& nbsp; Yaw getting in and out of the little b & bs & nbsp; what I know is that while stopping and getting up on the hill) there is something in the front of the vehicle behind it) & nbsp; for example, when I enter the road that is not properly smooth, my dear jazz peace jerky gacur offf offff ..... It looks like the car is crying :)
08.05.2020 16:13 # 2
Walla teacher, I have an interesting voice in the morning, and when I do a full turn, it is like a purse, a bit of a whirlwind.
08.05.2020 16:13 # 3
djchaos
[QUOTE = htasay] walla teacher has an interesting voice in me in the morning and it happens when I do a full turn, we said it was like a screeching gırç like something rubbing it to the master, but I don't know [/ QUOTE]
& nbsp;
Can you hear that sound when you turn the steering wheel? & nbsp; like a squeak & nbsp; is it like a car's chest? when I turned the steering wheel to and fro, there was a sound like the door creak, sometimes I heard this sound as I was passing through the bumps, I changed the upper parts of the shock absorber (hawk peugeot) I took the original part and the sound was cut off and there is neither creak nor sound, it is not the same problem, but there is a benefit to look at < / strong>
08.05.2020 16:13 # 4
dukenukem82
How many TL top balls?
08.05.2020 16:13 # 5
assat76
are back torsions if they do it in turns.
08.05.2020 16:13 # 6
There is no sound in me as if it comes from the belts inside the hood, but only in the first morning, the bidet feels as if it gives gas while turning the steering wheel. I'll show you tomorrow. Let's look at the master.
08.05.2020 16:13 # 7
oguz6578
The sound event has nothing to do with working in the morning, my friends' voice problem, my morning stop and kicking another problem ..... & nbsp;
One of the other problems is that when turning the steering wheel, the power of the headlights decreases ..... & nbsp; when the vehicle is stationary, the power of all lights will decrease and return to normal while turning.
08.05.2020 16:13 # 8
zavur
Interasan is a situation, not kicking in gas and gas. I do not know how accurate this system is in your vehicle, but I do not know how this system is, but when it was on the gas, it had a hose from the bottom to warm up immediately in my old vehicle, when that hose came out in its place until it warmed, & nbsp; Maybe it's something for you & nbsp;
08.05.2020 16:13 # 9
oguz6578
What kind of a hose and where is there a representative photo?
08.05.2020 16:13 # 10
oguz6578
There is no LPG issue in the mornings or after a long period of time after the vehicle is running. No problem when LPG is hot.
08.05.2020 16:13 # 11
oguz6578
Today, I asked the engine to stop, he said to the master, he is doing something from the valves he said, it is happening with time, but I said that when the heat is over, it is not so, why did I say that the material will expand when it gets warm and it will fit in place? 800 lira fln said he asked for 10 thousand maintenance 170 170 lira said :)))) & nbsp;
08.05.2020 16:13 # 12
aspirinxlarge
Reviews
08.05.2020 16:13 # 13
aspirinxlarge
If there is sound while turning the steering wheel, I would like to look at the steering pump. & Nbsp; The same sounds for me, but it is not a strange sound, just a little cycle. the room is not already a fault. But if I think the creak and the like sounds to me, show it to a master. As soon as you feel something wrong with the vehicle, at least as soon as you feel something wrong with the car, you will tell your master what the problem is. & Nbsp;
08.05.2020 16:13 # 14
tilbe307
friends, I have similar problems. i'm a trap in voices. There is a rubber part on my master front team. He said that there is no problem when they change. it really shows up when you turn the steering wheel of the car. rubber or plastic parts deformed over time. Reviews
08.05.2020 16:13 # 15
tilbe307
did you clean the throttle? Have your spark plugs checked.
08.05.2020 16:13 # 16
erden1978
[QUOTE = oguz6578] 307 sw petrol + lpg I have the problem of stopping when I start my car in the morning, but it only happens when the engine is cold at the first start ..... And when I start it is a misfire in the car when it is at first start it is like the engine will stop for 10 seconds when it is cold. it takes a little gasoline or pulls it by force, i know what it kicks in the first 10 seconds then it gets better ... but when i have lpg, i have no problem neither misfire nor anything happens when the engine is cold .... ..
And the bidet is now tired of the sounds coming from under the vehicle: (((((& nbsp; Yaw, while getting in and out of the little bunk & nbsp; what I know is that there is something in the front of the vehicle while standing on the hill) it eats it like that sound & nbsp; for example, when i get into the wrong way of the way, my dear jazz cuz gırgır gacur offf offff ..... it is as if the car is crying :)
Gasoline + Lpg in my vehicle.
When the vehicle starts for the first time in the morning, the engine warms up and the vehicle does not stop when it gives gas for 20 seconds or gives gas to the vehicle continuously for 1 minute.
Full No master who knows the problem said that a master in blue and green linens performs his auto jikle. They said it is broken. But I did not change it because I am not sure. I gave a reply to the question, yet it did not come out for this problem. If you find an answer, please share it here.
Regards ..
08.05.2020 16:13 # 17
And the bidet is now tired of the sounds coming from under the vehicle: fln in front of the vehicle, there is something in the back of plastic as if it is eating it, it sounds like a sound & nbsp; for example, when I enter the road that is not properly smooth, my dear, it is as if it is crying :)
08.05.2020 16:13 # 18
The sounds coming from the back to this problem may be from the plastic protections on the shock absorbers. The sounds coming from the front are caused by scraping from the rods, the shock absorbers and the plastic balustrades in the fender. I do not know that they do not think they will be too expensive, so the rubber parts that we call the front set are old.
If you have lpg installed in your vehicle, your vehicle gets the gasoline it needs by passing through the lpg system, so check it with a computer at least 2 times a year when entering and entering the summer, because you know that lpg summer and winter months Because of the cold and hot intensity fgarkl will prune in summer and winter, and because of the system's settings in the first study means a difference bay.
08.05.2020 16:13 # 19
erden1978
[QUOTE = 06ilhan06] the sounds coming from this problem are usually coming from the plastic protections on the shock absorbers. The sounds coming from the front rods are from the shock absorbers and the plastic railings in the fender are rubbed into the tray. I do not know their prices exactly, they do not think they will be too expensive, so the rubber parts we call the front kit are old.
It can be from the car's gas automatic spark plugs or spark plug cables. When you have LPG in your car, your car gets the gas it needs through the LPG system, so check it with a computer at least 2 times a year because it changes the operation of the vehicle because you know lpg or lpg. Due to the settings of the system, this means a difference in winter and summer due to the settings of the system.
İlhan bey.
If the vehicle does not work, the vehicle stops, until the engine warms up.
Do you have any suggestions about this?
08.05.2020 16:13 # 20
basrix
LPG should not be attached to 307 cars and some models especially, it causes a lot of breakdowns. Lpg grandfather does not save much money. 330 km long road car burns 60 TL gas. Gasoline 80 TL.
Page : / 2
