When my Peugeot 307 opens its doors, the trunk opens
08.05.2020 16:36 # 1
data123
Hello, when my 2006 model 307 premium hdi car opens its doors (whether it is remote or inside), the trunk lid opens as a roof. Why do you think it might be? I searched a little on forums. I found the same problematic tool in C4s. They told the master about a 200 TL expense. & Nbsp;
What could be the situation? Does anyone have the same problem? Thank you.
08.05.2020 16:36 # 2
tilbe307
& nbsp; the button of the trunk is touch, the button is filled with dust, dirt and mud, especially in the winter, and it gets stuck, and sometimes it opens on the road, sometimes it does not close when it is turned on, it puts the person back constantly. There is a method of this, we open the tailgate, you can remove the part that closes the button with a flat screwdriver and you can clean things like dust, etc. I am doing it at least and it is getting better. make it easy
tilbe307 2012-02-19 14:19:03
08.05.2020 16:36 # 3
data123
Thank you so much. I will try. It's been 4 5 months since I bought my car but the problem started when it snowed. As you said, I will open the plastic outside and clean it a little. I write the result here.
08.05.2020 16:36 # 4
http: // forum.peugeotturkey.com/forum_posts.asp?TID=21564&title=307-xt-bagaj-kilidi-sunun
last week, I shared the same problem here, and after it started to snow, it hurts spontaneously when I press the remote control ... I think water gets cold and freezes. When it touches it hurts spontaneously.
08.05.2020 16:36 # 5
data123
I was at home this Sunday, the car had a number of accumulated problems (as if we are using a classic car :)) I dealt with them. To solve this problem, I stretched the plastic cap on the top with a screwdriver and cracked, unfortunately :( I have to paint it in the color of the vehicle, even if I find the part. I am very sorry. I hope it won't last at least for a long time.
Be careful when disassembling that plastic piece.
08.05.2020 16:36 # 6
Thank you for your advice. The handle is yes in body color but the touch plastic on the bottom is black, did you break it?
08.05.2020 16:36 # 7
fince126
Mrb. My 307 also had the same & nbsp; problem. When the weather is nice today, I took the opportunity to remove the trunk release lock cover. a lot of dust has accumulated in it, I cleaned it, unfortunately, the part that serves as a spring on the back of the lid was broken while refitting it. but thank goodness it does not prevent it from working. There is already a button as small as a pin tip, very sensitive, it opens immediately when touched. You can open the cover by carefully pulling it from the sides with a small flat screwdriver. When installing it, there are two plastic inserts that act as hinges that hold the lid on the top. When he plugs it in and then pushes it up from the sides, it goes by clicking. When I pushed the cover towards the back of the hinge part without paying attention there, the spring part in the back was broken. But as I said, it does not prevent it from working. Good luck with..
08.05.2020 16:36 # 8
altantezcan
yours is opening at least mine is not opening at all napcaz & nbsp; "Big
08.05.2020 16:36 # 9
data123
There is a plastic piece outside, on top of the latch we hold to open it, it cracked. There is no problem with the plastic part we are in contact with (in the color of the vehicle) and the working system. Anyway, it is not very clear, but I am a little depressed at first. I'm not shaking too much now. Such things happen.
08.05.2020 16:36 # 10
fince126
What you are saying is the outer cover, which is seen from behind, is not easy to break, but it does not have anything to do. If it does not stand out very much, I think your mind will get used to it soon.
08.05.2020 16:36 # 11
data123
Exactly that cover, I'll leave it anyway, if Allah does not show it, if it is necessary to paint a part of the car, then I take it with the piece. & Nbsp;
08.05.2020 16:36 # 12
thank you for your information as soon as possible let me do a nice cleaning ..
08.05.2020 16:36 # 13
bulent 77
The classic 307 problem was at the old 307 m. I would be resilient in the winter. I used to heat it off with the last lighter. Bidet would open and close after washing the sunroof. Finally, the CD changer would stop and stop.
08.05.2020 16:36 # 14
altantezcan
[QUOTE = bulent 77] The classic 307 problem was at the old 307 m. I would be a resilient in the winter. I would heat it off with the last lighter. Bidet sunroof would be turned on and off after washing. Finally, the CD changer would stop and break.
Wouldn't it be enjoyable or yater? "Big
08.05.2020 16:36 # 15
data123
There is an electrical problem in the vehicle, it is certain :) But such problems get the worst problems. These are not huge costs. & Nbsp;
As you said, the type of vehicle is sufficient, the image and comfort are very good. The engine is also nice, I am very pleased.
08.05.2020 16:36 # 16
I'm glad too. As we said, the only problems are whether they leave me on the road or not with the permission of God. This comfort is not in any car.
08.05.2020 16:36 # 17
haritator
same problem same solution
08.05.2020 16:36 # 18
Emre GOK
The same problem was in my car, I took it to a acquaintance of a bodybuilder, he opened it, he did something, he fixed it, but in the meantime, this time (I think because of the cold) sometimes it doesn't open when I try to open the trunk, I try 3 or 4 times, but it hurts.
08.05.2020 16:36 # 19
drakman
Have a look at the service, find out how much. It doesn't seem like a problem you can solve.
