when I turn the steering wheel missing my hydraulic oil
08.05.2020 14:07 # 1
yasin_206
I felt that when I turned the steering wheel, the sounds come from the front, very rarely drip oil.
What should I do 1.6 gasoline 8 v
08.05.2020 14:07 # 2
kadir406
could be from the steering pump. I have the same problem I am looking for a steering pump .. humming dureection turns to the left as turn ..
08.05.2020 14:07 # 3
cerci07
If the oil drops, it means there will be a problem.
08.05.2020 14:07 # 4
HakanGokdemir
If you hear the sound when you put the steering wheel to the end, there are two reasons I know that either the pump is gone or the pump's pulley seems to be a pump, but it seems to be missing in the oil.
It was around 600 TL, 1.5-2 years ago, they can repair the pump in the authorized service, but in special services. Authorized service replaces the direct pump.
08.05.2020 14:07 # 5
hasimayaz
the pipe from the pump to the steering box is worn quickly .. check the condition .. there may be a leak in the seals.
08.05.2020 14:07 # 6
BurcUMUL
[QUOTE = hasimayaz]
I (206 GTI) had the same problem. I replaced the hose that Haşim Bey said. Our master pressed the hose with the same feature in the industry and there is no problem. Take a look at the hose.
08.05.2020 14:07 # 7
yasin_206
friends, the cause of abrasion in the aluminum pipe coming out of the hydraulic pump One of the plastic clips holding the pipe was opened and the pipe was worn with the engine shake and the oil started to leak, the new one was around 290 TL but it was repaired with aluminum welding. For .... tskkler everyone who responded, but the main reason for the problem is the enemy brain answer thanks, other friends say the pump is broken and officially passed in the past :) yasin_206 2009-12-24 20:53:02
