When I turn on the main beam, the dipped beam headlights go out. ?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Brands
08.05.2020 21:28 # 1
Simuzer
Hello, I formatted the brain of the car recently. I made some necessary settings. I even made the key identification. I just couldn't find the following setting.
Previously and normally; When you turned on the main beam, the dipped beam headlamps were still on.
Now; When I turn on the main beam, the dipped beam headlights go out and only the high beams are on.
Does anyone know where this setting is made? thanks.
The vehicle is Citroen C3 2003 model, I connect using the LEXIA program. The settings are roughly the same as the PP2000.
08.05.2020 21:28 # 2
It can be like this in some vehicles. maybe there is another option in the program. You have come to the standard settings because you format. Because the same basin is used with other tools. You may not have found the option you need to look for in the program.
24.12.2020 00:52 # 3
Simuzer
I found the setting. I got it back to normal. I don't remember which parameter was.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
