when I release the clutch, there is noise from the engine.
08.05.2020 18:24 # 1
rzsrht
when my friends run the car, the engine sounds when the car is idle. when I press the clutch, the sound stops. I don't know what it's about. I wonder if anyone has happened to you
08.05.2020 18:24 # 2
muku
The sound comes from the gearbox, not the engine, you need to change the balls, but in the short term it does not cause any trouble.
08.05.2020 18:24 # 3
cavit cevo
I have the same problem, I don't have a sound when I press the clutch.
Look at the expense
08.05.2020 18:24 # 4
kivanc
I guess it's the clutch ball
08.05.2020 18:24 # 5
lexelexe
I have had it for 2 years. If you get stuck in the sound in 307s, you have eaten the quince :)
08.05.2020 18:24 # 6
Bugra
clutch pressure is caused by pads usually that sound
08.05.2020 18:24 # 7
rzsrht
[QUOTE = cavit cevo] I have the same problem, I don't have a sound when I press the clutch.
Look at the expense
When you say look at the cost, my teacher Ermm ?? how much would it cost if we changed an estimated price?
08.05.2020 18:24 # 8
okankrgz
I know that the clutch ball needs to be changed so that it is not sold individually. The printing pad needs to be changed as a set.
08.05.2020 18:24 # 9
tlp
Mvzu transmission
I did this too
After replacing the pressure pad, a noise started with me
Sirf I sent it down again because of this sound
Download and remove the transmission, workmanship is more
Print bakata pattern and money
Workmanship on the ball requires finesse
I guess it costs between 500-700
08.05.2020 18:24 # 10
rahmi 206
I started doing the same problem when I changed the print-pad in 2011, and it still continues.
