When I Press Brake The brake pedal vibrates
08.05.2020 19:52 # 1
irfan
Hello friends My Tires were Old, I changed all 4 of them, but now Brake, even when I go at low speed.
08.05.2020 19:52 # 2
Dlkrn_48
My friend, I had the same problem. My master said that the brake discs were deformed over time as a result of contact with water while it was very hot. We gave 20 TL to the turner, 40 TL, they got workmanship and got rid of the problem. In short, you have to turn the brake discs into a lathe, but the problem is that after doing this kibu process, you have to have your pads sanded. That's why I managed it that way for a while and I turned the discs when changing the linings.
08.05.2020 19:52 # 3
samet206
As the friend said, the disks can create this problem. Otherwise, it is useful to check the balance, after you make the change, you notice the situation.
08.05.2020 19:52 # 4
Dlkrn_48
Doesn't the car tremble even if my friend is not braking because of the rotbalance adjustment? The best way to understand it is that you will press 130 - 140 on an empty and clean road, and if there is a tremor, I know that the vehicle should be rot-balanced. If I'm wrong, be forgiveness
08.05.2020 19:52 # 5
irfan
I had cleaned the brake discs with a cleaner spray, then I went directly to the car to wash, but the rod was not balanced, it was lifted to the norm. Should I take it again for ROT-Balance?
08.05.2020 19:52 # 6
talip206
I think your problem is about discs rather than Rot balances. When the pad and Disc are hot, entering the water or washing the vehicle can cause such problems. discs need to be turned.
08.05.2020 19:52 # 7
Fthz
When I was playing Citroen forums about how the C4 is used, I came across the pedal tremor event, that friend's problem was solved with rot-balance.
08.05.2020 19:52 # 8
xeelbug
I think it is not a balance if it is only on the brake. Either the discs are old and deformed. I do not know where you live, but in Istanbul, torners open only one tooth for 20 TL, if the situation is lathe, I will also find out the new disk prices.
Another option might be missing the Brake center, especially the upper center. There is something like a round tray at the place where the engine is in front of the steering wheel of the car; The servo. I would like to see if there is rust, paint, etc. on the surface of the ratio.
08.05.2020 19:52 # 9
samet206
Aside from the things that have become classic, someone who knows the vehicle even understands that the wheel balance adjustment is broken even at a speed of 70 km. then I suggest you look at the disks.
08.05.2020 19:52 # 10
irfan
There is no flickering in the steering wheel or in the car, I just think that there is an event like a kickback in the brake pedal.
08.05.2020 19:52 # 11
[QUOTE = ırfan] There is no flickering in the steering wheel or in the car, I just think that there is an event such as a kickback in the brake pedal.
No, my teacher is not about spray. the problem is most likely on the disks.
08.05.2020 19:52 # 12
okan77
The front discs will be turned on the vehicle or you will change the discs. There is no other option ... If you brake more than 90 km, only if you feel shaking until the steering wheel ...
08.05.2020 19:52 # 13
MadTurk_
the problem is only on the discs, as there is only vibration in the brake.
also, where did you buy the tire sent without your rod balance? interesting..
madturk_ 2016-06-27 12:31:31
