When I get my feet out of 307 gas, the car is cut
08.05.2020 17:21 # 1
beatles
friends, I need your help, when I drive my car, when I pull my feet out of the gas, there is a sudden interruption in the car. : 12: 41
08.05.2020 17:21 # 2
aknard
I have the same problem in 206, I did not have a problem, I change the problem as I do :) I think it may be caused by the gas wire. As you said, when the foot is pulled out of the gas, one of the back is pulling, even giving a feeling of braking. I heard that this happened more in 307s
08.05.2020 17:21 # 3
beatles
exactly like my brother they said it was very annoying, event injector or something clogged etc. I wonder if it is caused by clogged filters or something?
08.05.2020 17:21 # 4
aknard
I'm sure it's not from the filters. I just changed it, unlike all of them, more vehicles are cut :)
"Exclamati We need the help of our forums & nbsp; "Exclamati & nbsp; & Nbsp; & nbsp;
08.05.2020 17:21 # 5
aknard
güncellll ....
08.05.2020 17:21 # 6
beatles
brother, where is foruming, help and brother & nbsp; beatles 2013-02-11 12:53:18
08.05.2020 17:21 # 7
Serkan
[QUOTE = aknard] the same problem is not in my 206, I did not have a problem, I change it as I have a problem :) I think it may be caused by the gas wire. As you said, when the foot is pulled out of the gas, one of the back is pulling, even giving a feeling of braking. I heard that this happened more in the 307s [/ QUOTE]
Hodja, even though I do not know about the subject, I know that felineda has no throttle wire, the accelerator pedal is electronic.
08.05.2020 17:21 # 8
aknard
[QUOTE = Serco05] [QUOTE = aknard] I have the same problem in 206 too, I think it can be caused by the gas wire as the problem changes :). As you said, when the foot is pulled out of the gas, one of the back is pulling, even giving a feeling of braking. I heard that this happened more in 307s [/ QUOTE]
Hodja, even though I do not know about the subject, I know that there is no throttle wire, the accelerator pedal is electronic.
No one has had much experience on this issue, we are suffering from it :(
If the accelerator pedal is electronic, I do not think of anything other than saying we have a problem ...
08.05.2020 17:21 # 9
elsoberano
spark plug, spark plug rubber can be from the trilogy of the coil.
08.05.2020 17:21 # 10
aknard
let's take a look at the coil ... any other idea or prediction ?????????
08.05.2020 17:21 # 11
eray307
I have the same problem, I think it was caused by an engine ear or chock.
08.05.2020 17:21 # 12
beatles
Apparently, there is no more care left than going to the peugeot level, they said that it will be fuel. I started to buy fuel from opet for a long time.
08.05.2020 17:21 # 13
xMEGANx
I have the same too :) napcaz: d
08.05.2020 17:21 # 14
aknard
4-5 comfortably complain about the same issue. Ha, I pulled my foot from the gas, I was hung up on the brakes, doing the same treatment almost my car :)
08.05.2020 17:21 # 15
sezar206
the brakes may be tightening.
08.05.2020 17:21 # 16
emin15
I think your car is a gasoline manual gear
08.05.2020 17:21 # 17
NightKiss
[QUOTE = beatles] friends I need your help I need your help when I drive my car while I pull my feet out of the gas and suddenly there is a break in the car as if I am pulling the car from behind, I wonder what your time is waiting for your help [/ QUOTE]
< div>
I don't know if you have pejos but if there is a saddle, d unplug the clutch cushion. The problem will be eliminated. Try it, if the saddle is cutting again, he said, come on, if he doesn't, he said, continue.
08.05.2020 17:21 # 18
hllgdk
I have 2003 307 xt, just because of this, I hesitate to put someone in the car, especially when I cut the gas in the second and third gear, the car hitting it as if the gas is over, I said the coil, I changed the coil, I changed the motor ear again, the same is the same again: (((injector says now master
08.05.2020 17:21 # 19
MertMurat
It happens to me once in a while but it does not stretch
