When I dropped my car downhill, I spilled oil |
| 08.05.2020 18:21 | # 1 |
| 08.05.2020 18:21 | # 2 |
vehicles got confused when I saw a 406 last night, whatever I thought :) look at the brake hoses from them! new oil filter change? If they have just changed, they may not have installed original filters, they can make a room !!! |
| 08.05.2020 18:21 | # 3 |
The new unchanged filters have all changed 5 thousand km ago. I don't know if I see the brake hose so much :)
| 08.05.2020 18:21 | # 4 |
it is evident from the interior of the rim ... but my guess is that if the vehicle is level or downhill, the kidnapping will always happen.
| 08.05.2020 18:21 | # 5 |
can be from gear pad
| 08.05.2020 18:21 | # 6 |
[QUOTE = dogan106] can be from gear seal [/ QUOTE] Look, I did not think of this. Thank you brother for the reminder. If there is a deformation of the felt in the downhill slope, there is a high probability of leakage. But it will be a little leak, it doesn't matter, but if it doesn't stay over time, it gives the transmission to the man's hand.
| 08.05.2020 18:21 | # 7 |
[QUOTE = Kuscu38] [QUOTE = dogan106] may be from the gear pad [/ QUOTE] Look, I did not think of this. Thank you brother for the reminder. If there is a deformation of the felt in the downhill slope, there is a high probability of leakage. But it will be a little leak, it doesn't matter, but if it doesn't stay over time, it gives the transmission to the man's hand. [/ QUOTE] ![]() ![]() ![]() My investigator is not automatic, but the gears are already beating with the power of faith.
| 08.05.2020 18:21 | # 8 |
[QUOTE = Mbiwa] [QUOTE = kuscu38] [QUOTE = dogan106] can be from the gear pad [/ QUOTE] Look, I did not think of this. Thank you brother for the reminder. If there is a deformation of the felt in the downhill slope, there is a high probability of leakage. But it will be a little leak, it doesn't matter, but if it doesn't stay over time, it gives the transmission to the man's hand. [/ QUOTE] ![]() ![]() ![]() My investigator is not automatic, but the gears are already beating with the power of faith. [/ QUOTE] ![]() ![]() ![]() |
| 08.05.2020 18:21 | # 9 |
Well, if I go to the industry and say to one of the master, the gear pad is missing the oil, how much will it explode in Istanbul?
| 08.05.2020 18:21 | # 10 |
where are you in ist
| 08.05.2020 18:21 | # 11 |
K.çekmece
| 08.05.2020 18:21 | # 12 |
[QUOTE = Mbiwa] Well, if I go to the industry and say that one of the master changes gear pad oil, it explodes in Istanbul [/ QUOTE] I think when he goes to industry in asking that way. I do not know exactly where there is oil leakage in my vehicle, they can be from the gearbox, if you say there is a difficulty in shifting the gears (you wrote above) they say something clearer.
| 08.05.2020 18:21 | # 13 |
ahmed206 |
I think park it uphill again, look at least, what's left somewhere is spilled or is there a real problem?
| 08.05.2020 18:21 | # 14 |
[QUOTE = ahmed206] I think park again on the slope again look at least whether somewhere is spilled or is there a real problem ... [/ QUOTE] If you saw the first time, there is oil or if you see my continuity for the first time, park it in another place right, friend, make sure it is clean !!!
| 08.05.2020 18:21 | # 15 |
It was like 2 weeks or so, but I didn't care that it seemed to be stuck in my head today, or it seemed to me, but there are 99 percent problems, I am very unlucky.)
| 08.05.2020 18:21 | # 16 |
Hodja, if there is a leakage of oil, I think there is no slope.
| 08.05.2020 18:21 | # 17 |
Mrb..dun could not pass the examination They said there was a crack in the right and left brake hoses ... then they got to the master ... they said 130 TL including labor ... what do you think ... |
