When I cut the gas, I have a muscle but why ??
08.05.2020 15:57 # 1
I said the 2003 model car is normal, but I used your friend's megan.
When I pull my foot out of the gas while driving on the normal road, there is an accumulation in the car.
huseyinturk 2011-08-08 07:33:52
08.05.2020 15:57 # 2
Could it be related to the shaft with no knowledge?
08.05.2020 15:57 # 3
metin
I think it is normal because the engine brakes when you pull your foot off the gas,
08.05.2020 15:57 # 4
it doesn't have anything to do with mottor brake, but the moment I pull it off is that the car is returning to normal after the car.
08.05.2020 15:57 # 5
metin
I wonder whether the fuel is cut off suddenly, it seems like fainting in the vehicle,
08.05.2020 15:57 # 6
I do not think it is from fuel, for example, when the car that moves slightly, releases the clutch on the 1e launcher, it will either move first and then move to the same shape.
08.05.2020 15:57 # 7
qqyyxx
Usually, when the air conditioner is on. When you suddenly take your foot out of the gas, it makes a noticeable softening, especially our 1.4 hdi engines. If there is any other softness, the healthiest one is to have it tested at the service.
08.05.2020 15:57 # 8
As you said, do more with the air conditioner on
08.05.2020 15:57 # 9
vbmaster
If you solve it or if you find out why it originated, share it here ... let us find out ....
08.05.2020 15:57 # 10
I share but it will take a few weeks and let me see if the subject loses its current status
08.05.2020 15:57 # 11
don't you have any other ideas?
08.05.2020 15:57 # 12
It makes 1.4HD 307s. They do it all, so it's not just yours. I also used 1.4 HDi 307 for a long time and it was contracting when I pulled the foot out of the gas.
08.05.2020 15:57 # 13
vbmaster
What makes it interesting is that standard Pugs are hard to understand sometimes :)
08.05.2020 15:57 # 14
I wonder if this is the norm of this vehicle or it is a malfunction with time. Maybe it happens when the motor ears are broken etc. It is necessary to examine the master to examine it ...
08.05.2020 15:57 # 15
Let's put a spring under the gas, let it be mounted on the ground, let it slowly release from the gas in the check, I think we will unravel the pedal. GKN 3
08.05.2020 15:57 # 16
[QUOTE = CeCoLi] I wonder if this is the normal of this tool or it is a malfunction with time. Maybe it happens when the motor ears are broken etc. It is necessary to examine the master to examine it ... [/ QUOTE]
Normal brother. My father is using 307 1.4 HDi now. We bought the vehicle on time. The same situation was when it was first received. We were even quite a fool. Now the vehicle is in 105 thousand, it still exists, we are used to it
08.05.2020 15:57 # 17
[QUOTE = mustafa_uslu] Let's put a spring under the gas, let it be mounted on the ground, let it go slowly out of the gas check, I think we will solve the pedal so that GKN 3 [/ QUOTE]
Gülme No way. If you say why, the gas pedal has a point, when it comes to that point, it does the muscle.
08.05.2020 15:57 # 18
I asked a master, he says if the engine is new, it is tight, there may be a gap in the shaft, the piston may want adjustment, in short, every thing I ask says something else.
08.05.2020 15:57 # 19
