When does ALTERNATOR TENSION BEARING change?
08.05.2020 19:53 # 1
ahmet_bjk
Hi
When is it necessary to replace the tensioner bearing?
My vehicle 2009 model 308 at 77,000 km. I am thinking of changing the timing set. Is it necessary to replace the tensioner bearing?
08.05.2020 19:53 # 2
[QUOTE = ahmet_bjk]
Hi
Exactly, you will change the timing set, teacher, you will not give any more workmanship and you will be comfortable. The triger is already sold as a set. If we summarize the parts that will change.
1- timing belt and bearing
2-circulation pump (definitely replace.)
3-alternator belt and bearing.
I strongly recommend you to buy these pieces originally.
