Wheel Tire Selection
08.05.2020 19:46 # 1
akundakci
Friends I found 205.40.17 rim + tire 2013 production clean tires I want to install 306 ma car original unmodified torsions made new I wonder if it would be a problem?
08.05.2020 19:46 # 2
Well, my teacher, that size is very big, I am max. I don't think over 16. If I have money now, I would use 15 wheels 195/50/15 tires
08.05.2020 19:46 # 3
akundakci
I said let me ask you when I found it affordable, soner, thank you.
08.05.2020 19:46 # 4
GokhaN
If there is no problem in the offset of the rim, I think it will not rub. a little careful use you don't make a full tour, I don't think there will be a problem
08.05.2020 19:46 # 5
akundakci
Thank you I will consider your warnings
08.05.2020 19:46 # 6
omer_tarsus
If the original size of your vehicle is 175/65 r 14, this tire upper part will be 0.5 cm closer to the fender and will be 3 cm wide.The room has so much distance that makes 1.5 cm inside and outside. I think it would be beautiful, it would look good and there would be no problem with rubbing, but I cannot say anything to comfort.
