wheel tire problem
08.05.2020 16:19 # 1
34sea45
friends bought a 106 xr rim tire on the market
rims 14 tires 185/55/14 but i have a little problem
i dont count the friction pits even if i have 5 years old child in the back seat any torsion settings fabrication any reduction process none
there is a 3,5 cm spring in front, there is no problem at the front, but there is a bad rub at the back. buy tires
remove 3 torsions (I do not know if it is possible)
what could be an alternative to them or which of these would you recommend?
this is the only picture I have
34sea45 2011 -11-01 20:11:29
08.05.2020 16:19 # 2
Although my torsions are low, it doesn't rub even if there are 2 people at the back. Our tire rim dimensions are the same. Is there a difference in the case: S
08.05.2020 16:19 # 3
I think the number 1 is the most logical offsetlimiki is it rubbing it from the rim?
If we see a couple of pictures, then also :)
08.05.2020 16:19 # 4
There Is No Relevance To Torsion This Job ...
From Boredom Rim Offset
08.05.2020 16:19 # 5
34sea45
my colonel is not an offset event.
xr back rear fender is narrower than the quick right now the only solution seems to be to open the fender.
08.05.2020 16:19 # 6
I had the same problem in my previous car.
There were 17 inch wheels. It made my car look nice and charming.
but I couldn't put anything in the back of the 3rd person and the trunk.
When I went on vacation with my car in the summer, it was loaded with luggage. But nobody was sitting behind.
I have eaten the rear mudflaps until it is gone from rubbing.
this is your friend in your problem. wrong tire and tire selection.
the tire has no fault in this regard, the wheel disrupts the job.
08.05.2020 16:19 # 7
34sea45
There is the most suitable tire size recommended for 106 now
I just came out and examined a bit and I just saw that the muddy's inner bend was rubbing, it probably won't rub it when it folds, but let's see if I buy it or buy it with someone else.
08.05.2020 16:19 # 8
You need to reduce the size of the sole, not the cheek, vigorous. If we replace 175 with 185, the problem will disappear.
or if we deal with the muddle a little bit, there will be no problem rushing, tire change will be more smooth.
08.05.2020 16:19 # 9
Diner, should I say something to you !!! I was going to rob the day I saw it, but I didn't want you to be broken.
& nbsp;
What is wrong with you is neither tire sidewall nor tire width. That rim is not for your vehicle. Because we're out. That's why the mudguards are blowing his mouth ...
08.05.2020 16:19 # 10
34sea45
let's see cem abi is probably melon tire making tool
34sea45 2011-11-02 11:04:43
08.05.2020 16:19 # 11
[QUOTE = 34sea45] let's see cem brother most likely melon tire making tool
& nbsp;
Is "Melon rubber" "C & nbsp; & nbsp;
I think you're talking about medicine where the rims are wider than the tire ...
& nbsp;
& nbsp;
& nbsp;
08.05.2020 16:19 # 12
okan77
106 sx / xr no matter what rim, if you use 185 55 14 size, the cheek part will rub against the fender. It is stable with experience. Either you will knock the fender, there is no other remedy. The problem disappears when the share inside is folded in 1 / 1.5 cm width. But if it has previously been painted, if there is a paste, I would like to say that it will start to paint after folding.
08.05.2020 16:19 # 13
Dinçer do not need a flange for these, maybe if you put a flange on the rim, the problem will disappear ...
08.05.2020 16:19 # 14
the rims are big and offset, but I hit the excess in the fender, I have no problem right now. Ask the tire if you want this event ...
08.05.2020 16:19 # 15
the flange is most likely because every rim is not 106 or without flange ..
08.05.2020 16:19 # 16
Take a look at the distance behind the tire in the fender, looking at the bottom of the Dincer vehicle. I wonder how much space is there ??? I was curious about the offset and width of the rim
08.05.2020 16:19 # 17
34sea45
We got over the problem by opening the fenders, no more friction like rubbing, but no rubbing occurred even though we collapsed to the rim
08.05.2020 16:19 # 18
[QUOTE = 34sea45] We got over the problem by opening the fenders, no more friction like rubbing. There was no friction even though we crashed the rim until [/ QUOTE]
& nbsp;
Good luck then use gule gule "Eye
08.05.2020 16:19 # 19
Get well soon, brother :)
08.05.2020 16:19 # 20
34sea45
thank you brother bro you have passed
cem brother offset size or something i do not understand the power otherwise i would have said it but it was no problem anymore
Page : / 2
