Wheel Selection
08.05.2020 20:44 # 1
kayaca
friends, good night tell me I have a question
I have a coil in my vehicle
207 rims have 15 inches 65 sidewall tires
i am thinking of changing the rim
We call it 15 inch 55 cheek cc rim or
We call it the 17-inch 45-cheek rc rim, which one looks better, or does this 17-inch increase fuel or friction? Will 15 inches remain small?
08.05.2020 20:44 # 2
maximusti
if the vehicle is 206, to pass 16 ",
I had 16 "Porsche wheels (very similar to the CC rim), even if 1 person on the back seat was rubbing, the 17" wheel would tire the vehicle.
08.05.2020 20:44 # 3
onlycihan
https://forum.peugeotturkey.com/forum_posts.asp?tıd=44537&title=sana-kirmizi-cok-yakisiy is
this is a subject I opened before. I have a rim with a 195/55 / r15 wheel combination, the springs are original and it looks like this vehicle. We are a family of people.
08.05.2020 20:44 # 4
kayaca
[QUOTE = onlycihan] https://forum.peugeotturkey.com/forum_posts.asp?TID=44537&title=sana-kirmizi-cok-yakisiyor
masallah, my teacher, allah, it will help you to ride without any accident insallah i want it cut out hojam so it is close to the ground now it has coil on it I think it is 5 cm I think 65 sidewall tires vsar rubbing rubber 3 people get closer to the ground when we get 55 cheek tires Does it look small, so I wanted to get an idea, like I would give up 17 inches. If the vehicle remains flat on the rim or if the wheels appear small or small, how do we lower the rear torsions?
08.05.2020 20:44 # 5
kayaca
[QUOTE = maximusti] If the vehicle is 206, do not exceed 16 ",
For your answer, my teacher, he has 15 inches 65 cheeks on the moment, he rubs with 3 people.
08.05.2020 20:44 # 6
onlycihan
cheek thinking will decrease both the height of the vehicle and the tire fender will be opened. But 65 cheeks and 55 cheeks make the tire noticeable in terms of comfort, it has a harder structure. even if there are 3 people sitting, you think you will use it even lower. This rubbing will be inevitable.
08.05.2020 20:44 # 7
kayaca
[QUOTE = onlycihan] cheek thinking will decrease both vehicle height and tire fender will be opened. But 65 cheeks and 55 cheeks are noticeable in terms of comfort, it has a harder structure. even now, even if there is a little bit of rubbing in the back, 3 people are sitting, you are thinking of using it even lower. This rubbing will be unavoidable. Some of them open their fender mouths for the solution, but there is no need for the solution.
the point I think is that the distance between the wheel and the windshield is not very much, because I think that the sex will stop, 1 finger on 65 sidewalls, so I do not want to prefer 55 inches on the sidewall so I do not want to prefer 15 inches, but I would like to prefer others.
08.05.2020 20:44 # 8
onlycihan
my car is not flattened at all and it stops with you 15/55 tires at most
08.05.2020 20:44 # 9
maximusti
[QUOTE = rock] [QUOTE = maximusti] If the vehicle is 206, do not exceed 16 ",
the gap increases as the cheek falls ..
Comfort decreases as the cheek falls .. My 16s had 45 or 50 cheeks, you can feel it if you crush the fly on the ground.
08.05.2020 20:44 # 10
kayaca
[QUOTE = maximusti] [QUOTE = to rock] [QUOTE = maximusti] if the vehicle is 206, do not exceed 16 ",
I think it would be ideal if we do 15 to 55 rubbing.
