Wheel Nut Wrench For 206?
08.05.2020 17:43 # 1
rolandgarros
I don't want to buy a single wheel bolt key in my vehicle, but I didn't know how much I need to buy, so that the original fits well and does not take up much space? I think it's number 17, but I wasn't sure, and I said I'll consult with your forums. Smile
08.05.2020 17:43 # 2
sezar206
He used the 4 key when disassembling the last tire, 19 if I remember correctly. If you do not have the original, you cannot unscrew the spare wheel, how will you remove it?
08.05.2020 17:43 # 3
rolandgarros
[QUOTE = fatihpekgoz] Used the 4-key when removing the last tire, I must be 19 if I remember correctly. If you do not have the original, you cannot unscrew the spare wheel, how do you remove it? [/ QUOTE]
There is no encrypted bolt, I renewed the rear tires, they opened there smoothly.
08.05.2020 17:43 # 4
TuNeR_32
Number 17 I dismantled today to paint my rims ..
08.05.2020 17:43 # 5
Secks
Hodja, if you want to have the original key directly.
08.05.2020 17:43 # 6
sezar206
I didn't say for studs. There is a screw in the trunk so you can open the spare wheel well, and you can open that screw with the end behind the wheel wrench. So you should get the original key.
08.05.2020 17:43 # 7
rolandgarros
[QUOTE = fatihpekgoz] I didn't say for the studs. There is a screw in the trunk so you can open the spare wheel well, and you can open that screw with the end behind the wheel wrench. So you should get the original key.
hmm thanks I will get the original already Smile
[QUOTE = Secks] Sir, if you want to have the original key.
Tomorrow I will buy a 4-wheel wrench from a brother a101 and he will give me his 206 Smile if not, I would buy it. I wouldn't miss it because I was the original Smile thank you for your interest, I wish you good sales Wink
08.05.2020 17:43 # 8
rolandgarros
[QUOTE = TuNeR_32] Number 17 I removed it today to paint my rims .. [/ QUOTE]
Thanks, I will start preparations for rim painting. LOLLOL
08.05.2020 17:43 # 9
TuNeR_32
Do not buy from a101 there are kins made in china 2 times I broke the industry, was there a brand like eta I would recommend it very high quality price 20.00 TL
08.05.2020 17:43 # 10
ahmet_bjk
the original wheel wrench is not very sturdy.
I had to press it with my foot because it was so tight, I couldn't open the key in the 5th bolt, I couldn't open the 5th with that key
08.05.2020 17:43 # 11
x571
[QUOTE = ahmet_bjk] original wheel nut wrench is not very solid.
are you sure it's original. I'm over 90 kilos and spring up to tighten well. Nothing happened
08.05.2020 17:43 # 12
OguzhanKucuk61
[QUOTE = cesar206] I didn't say for the studs. There is a screw in the trunk so you can open the spare wheel well, and you can open that screw with the end behind the wheel wrench. So you should get the original key.
There's nothing locked in me. Under the carpet of the trunk, my spare tire just stands unlocked. What was asked to explain in this message?
08.05.2020 17:43 # 13
maximusti
[QUOTE = OguzhanKucuk61] [QUOTE = sezar206] I didn't say for the studs. There is a screw in the trunk so you can open the spare wheel well, and you can open that screw with the end behind the wheel wrench. So you should get the original key.
There's nothing locked in me. Under the carpet of the trunk, my spare tire just stands unlocked. What was asked to explain in this message? [/ QUOTE]
I think the spare wheel in 206 sedans is in the trunk,
hatchback 206 has a screw that holds its cage outside and inside the trunk,
this screw opens with the back of the original wheel wrench.
08.05.2020 17:43 # 14
OguzhanKucuk61
[QUOTE = maximusti] [QUOTE = OguzhanKucuk61] [QUOTE = cesar206] I didn't say for the studs. There is a screw in the trunk so you can open the spare wheel well, and you can open that screw with the end behind the wheel wrench. So you should get the original key.
Now it is resolved, thank you teacher
08.05.2020 17:43 # 15
tired06
I don't have a bolt wrench, we open it with it, no tire has blown, but I hope it won't explode in a ridiculous place
