Wheel Nut Password :(
08.05.2020 16:52 # 1
osterreich
friends & nbsp; 3 & nbsp; what I will come to the trail after the day. (one way 1900 KM) & nbsp; & nbsp; Today I said I would check the tires and wheel bolts, when I started to follow the password to the bolt, the blank started to turn and the inside of the password & nbsp; I selected a & nbsp; I noticed that 3 out of 4 separate teeth are missing. If you can help & nbsp; & nbsp; I have 3 questions;
If my tire bursts on the 1st Road, I hope I can do this if I do not have a situation like this? 3. If you say you can't get rid of, can we make a copy of the tornacida or password?
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp;
& nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; TESEKKÜRLER
08.05.2020 16:52 # 2
The screwdrivers can be screwdrivers. I also read in the forum, they weld the other of the encrypted wheel bolts to the top and open it up. If you want it to be done before you go, it will not be in your mind. Not less than 1900 kilometers.
08.05.2020 16:52 # 3
sercinho
open the airplates in the tire manufacturers.
08.05.2020 16:52 # 4
toga406
There is foam for 15 TL and throws to the nearest tire. There are tire stores in shopping places. squeeze into the nearest tire without too much speed
08.05.2020 16:52 # 5
volkan_uysal
The scrambled wheel bolt cannot open the tire man, without a password. I went to know the lathe in the industry and worked for 1 hour after welding, we made a special apparatus and removed it by force. I immediately deciphered the other 3 tires and threw them as normal. In fact, I wrote about this incident here to pay attention to the passwords :)
08.05.2020 16:52 # 6
feline
scrambled bolt event was somewhat fashionable, but I see it no longer happens even in zero cars
08.05.2020 16:52 # 7
wolf72
I changed it at 4, I did it without a password, when my head was comfortable, when I go to the tire and change the cottage with the winter, I was looking for it.
08.05.2020 16:52 # 8
pierson
hello friends ... when i bought my car i didn't know if there is a wrench key..but i have not seen it..they will get the wrench key here..one side bolt the other side like screwdriver head..so i like the original peugeot bolt..want to ask for it .. The titles are changing. Do I need to buy 17 or 19? 2002 peugeot xr auto ..
08.05.2020 16:52 # 9
pierson
[QUOTE = pierson] hello friends ... when i got my car i didn't know if there is a wrench key..but i have not looked anyway..they will get the wrench key here..one one is bolt, the other side is like screwdriver head..so the original peugeot wheel bolt..this I want to ask .. the bolt heads are changing. Do I need to buy 17 or 19? 2002 model peugeot xr auto .. [/ QUOTE]
friends did not write a ceap ... now i will order ... key 17? Is it 19? Please let anyone know?
08.05.2020 16:52 # 10
Serkan
I am not sure if it is 17, you can get the best from 4 ones, it is both guaranteed, it is much more comfortable to use and you can use it in other vehicles.
08.05.2020 16:52 # 11
pierson
So how do I remove the spare tire then ... if you are sure I will order it as 17
08.05.2020 16:52 # 12
Serkan
I'm not sure, buddy, but I can answer for sure tomorrow afternoon
08.05.2020 16:52 # 13
rolandgarros
actual
08.05.2020 16:52 # 14
pierson
I bought a 17-wheel bolt key, and it did not happen ... it came to my car ... it was small, so in this forum, I did not know the number of the key of my car, whether it is halal ... everything from the crankcase to the chambers inside the exhaust is known, but the nut of the bolt key is unknown ... interesting ... surprised ... good health ... good forums ...
08.05.2020 16:52 # 15
plawert
If you are not sure how you will know the size of your wheel bolt, you will try it. Take whatever you use
