WHEEL COMPATIBILITY?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Other Models
08.05.2020 20:06 # 1
pejo107
Hello friends, I would have 2 questions,
The tire in my car is 155/65 R14
a friend of mine has a tire set with a 185/65 R14 steel rim.
1. Would it be appropriate if those tires and rims are installed directly in my vehicle
2. Can I just take the rims and attach them to my existing tires?
08.05.2020 20:06 # 2
1- The possibilities will be great for 107 rubbing.
There may be 2-rims. How many studs should you look at in the 107s
08.05.2020 20:06 # 3
pejo107
thank you
08.05.2020 20:06 # 4
Narkotik
If the stud spacing is suitable, it reads or cuts the stud
08.05.2020 20:06 # 5
OguzhanKucuk61
1- It rubs. Even if it does not, such a wide tire increases both fuel. It both hardens the steering wheel. in addition, it contributes to handling in the winter.
2- As Soner said.
08.05.2020 20:06 # 6
ggitaristt
Friend, we do not know if the rim is offset .. 185 may not rub.
Stick on the front, back, one wheel, and the wheel bolt is compatible or friction.
