Wheel Care .... !!!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 16:12 # 1
Uploaded with ImageShack.us Unfortunately, your wheels are always the dirtiest places of your vehicle. Because they are contaminated with foreign substances such as brake (lining) dust which has abrasive properties, salt environment in the ocean and road, stones and gravels and various other wastes. Pay attention to paint and coating of your rim as much as you show your body. Today, most alloy wheels have a painted and / or coated exterior. The best way to clean this delicate paint and / or coating layer without damaging it is to wash it with a mild, mild soap and clear water. Periodically polishing your rim will protect your rim surface from external elements. Never use abrasive cleaners, metal-added cleaning sponges, polishing compositions. Avoid automatic washes. Some automatic wash stations use acid-added cleaners before or during washing to remove the dirt on the vehicle. Some use hard brushes to clean the tires and wheels. In these two types of processes, it damages the outer surface of your wheel. Before putting your car into automatic washing, ask the authorized person what kind of equipment he is using. Never let your tires and wheels be cleaned with steam. Cleaning with hot steam will cause the paint and coating of your wheel to become dull. Do not clean while your wheels are hot, wait until it cools. The water dries faster at high temperatures. That is why if you do the cleaning process while the rim is hot, the water and soap mixture you clean will dry faster and there will be a soapy layer or stains on the rim surface. It may be a good idea to keep your car in a shady place for 1-2 hours before washing it. Cleaning the wheels one by one is always the healthiest method. If you leave one soapy and try to clean the other rim, the soap on the other rim surface will dry and stains will occur while you are dealing with the other rim. If you are going to continue cleaning your car after cleaning your rim, be sure to change the brush or sponge that you use when cleaning your rims because the brush or sponge particles that get on the sponge can scratch the body of your vehicle. Think of your new tires and wheels as if they were any investment.
08.05.2020 16:12 # 2
Surucen Arab soap brush on top of the garden hose All right: D & nbsp;
08.05.2020 16:12 # 3
Thanks for the information Ersinim Bide has another topic I would like to learn. What kind of liquid and parts should we use to clean the under engine parts of the hood?
08.05.2020 16:12 # 4
metin
[QUOTE = EmRaH] process arabic soap brush above the garden hose water all request: D & nbsp; [/ QUOTE]
& nbsp;
walk & nbsp; bee emrah,
& nbsp;
again, you stopped, you came out, you mixed it up hee & nbsp;
& nbsp;
08.05.2020 16:12 # 5
metin
Good health.
08.05.2020 16:12 # 6
Let it be healthy. Otherwise, the lining dust will build up over time ... During this time, sizzling hard liquids should not be used and on the contrary, we should prefer substances that will not cause soft damage. Otherwise, it is very possible to damage the exterior paint of the rim ...
08.05.2020 16:12 # 7
Personally ... I Wash My Car With Wheels
IPEK Brand Shampoo ... I Recommend It To Everyone ...
Oily Hair as a Model
08.05.2020 16:12 # 8
metin
[QUOTE = AlbaYDemircaN] Personally ... I Wash My Wheels In My Wheels
Oily Hair As A Model
[/ QUOTE ]
& nbsp;
oiled wheels as model "Laughter"
08.05.2020 16:12 # 9
Tighten the engine oil remover to the rims for 1-2 minutes and get the brand WURTH. then wipe it with a cloth, let's see how it shines, it's almost lip-like & nbsp;
08.05.2020 16:12 # 10
mimitt
I use 2 different products for the process, the first one is Meguiras's rim cleaning spray i use this every time. The second is the intensive rim cleaner of sonax, you have to be careful when using this product, it contains more solvent than a normal rim cleaning fluid, so it damages the paint frequently. For deep-scratched wheels, it is not recommended anyway.
08.05.2020 16:12 # 11
I Love My Pug
Thank you very much for the information :) My wheels are black now :) I hope if I can find time to clean it soon.
