wheel bolt measures help
08.05.2020 16:06 # 1
murat deniz
friends, are the bolt sizes of all 206 models the same? & nbsp; I would appreciate if friends with knowledge inform. respects..
08.05.2020 16:06 # 2
tigerland
I know that 4 x 108, & nbsp; 19 Bijon standard. If it is wrong fix it friends
08.05.2020 16:06 # 3
4x108 yes, just like Erbin said ..
08.05.2020 16:06 # 4
MemoTech
The 19-wheel bolt seems to overlap some GTIs. I know the normals are 17. The subject of 4 x 108 is correct.
08.05.2020 16:06 # 5
murat deniz
Thanks for your answers, friends. Well I have one more question, I would appreciate it if you could help. I bought a 15 "307 5-spoke wheel, 2nd hand. Can I use the original wheel bolts used on my hair wheels?
08.05.2020 16:06 # 6
MemoTech
I was not able to use the original sheet metal wheel bolts for the 206 GTI rim. I had to use the original 19mm sequins GTI studs. The wheel bolts of the sheet rim were small and short. Remove one of your wheel bolts and put it on the empty wheel. Or falls into the middle of the hole? If possible, try to get the wheel bolts from the person you bought the rims.
