wheel and tire sizes
08.05.2020 16:05 # 1
murat deniz
friends, I intended to change the rim, I want to change my original hair rims but it is simple but maybe there is something I do not know, I would be glad if you help. I am thinking of installing 15 "wheels on my 206 vehicle, if I don't know, can all wheels have 185-195-205 based tires, or does each wheel have its own size? Thanks ..
08.05.2020 16:05 # 2
First of all, would you write the original tire size ??? 175 65 14 ???
If it is possible, let's take a clear picture of the striker inside the door and make the description of the bay better.
08.05.2020 16:05 # 3
murat deniz
ok cem tomorrow morning i take the photo. as you said in the tire sizes 175 65 14. I will not affect the fuel too much, and I want something to save me from the hair rims. I would be glad if you have any advice. respects.
08.05.2020 16:05 # 4
In fact, the tire size of the cleat is "185 55 15" ...
The exact equilibrium of the original scale is 175 65 14 and the cap is 185 55 15. This is the original tire size measurement of the 206 GTI.
It can be used in 195 50 15 as equivalent to wool. But according to the original, 1.2% is small. However, since the base is 195, the fuel pulls out a lot, and since it has 50 cheeks, it decreases considerably in comfort. Ten teams in one get how they get from the situation ...
If you look at the situation, 195 50 15 looks much better. But if we look at the pain of functionality 185 55 15 one option ...
Let me create an example, I said to take a picture of that striker. We should look at the offset related information there.
In the case of rims, it would be nice if you choose a rim with 25 offsets ...
08.05.2020 16:05 # 5
If you say the size of the tire best suited to your vehicle is 195 * 55 * 15 but sports appearance is not important, you should prefer 60 sidewall tires, but you can not find 60 sidewall tires on 15 wheels in each brand. My advice is that if you do not drop your comfort, buy 185 * 60 * 15 tires, I use 185 * 55 * 14 on 14 wheels, and reduced my comfort noticeably.
08.05.2020 16:05 # 6
[QUOTE = CeCoLi] In fact, the tire size of the blade is "185 55 15" ...
+1
My 206 cars 1.6 LPG
Original tires 175/65/14
I wore it 195/50/15, I am very satisfied.
Brother Murat Deniz, be careful that the steel rims you will buy are light alloy because your vehicle is 1.4.
mustiii 2011-09-06 11:36:26
08.05.2020 16:05 # 7
metin
For peugeot models, there was a header about which rim and size of tire should be fitted, all of them were gathered there.
08.05.2020 16:05 # 8
[QUOTE = ümitarmatli] My nurse, the tire size best suited to your vehicle is 195 * 55 * 15, but if you say sports look is not important, choose 60 sidewall tires, but you can not find 60 sidewall tires on 15 wheels in each brand. My advice is that if my comfort does not fall, I buy 185 * 60 * 15 tires and I use 185 * 55 * 14 on 14 rims. It reduced my comfort noticeably. [/ QUOTE]
Hemser what are you saying Look at the love of God Let's see what I said above ??? SırıtmaSırıtmaSırıtma
195 55 We are in the car of 15 men. Based on what you are saying is the most suitable ??? Göz Kırpma
It soaks out from the original tire gauge. Gülme
08.05.2020 16:05 # 9
185/55/15 or 195/50/15 Thumbs Up
Since the vehicle is 1.4, I recommend 185/55/15. Loss of traction will not be more + road holding will increase a little + Fuel will not be affected almost ..
08.05.2020 16:05 # 10
By the way, the original tire size of my vehicle, the Cecoli, is 195/55/15. Therefore, it will not cause any problems when it is worn in other 206's. My vehicle fenders etc. I guess it's the same as the other 206. Even my winter tires are 185/60/15. Gülme
But when the friend wears 185/55/15, he will not spoil the factory value in diameter. So it is unnecessary to wear 195/55/15 ..
08.05.2020 16:05 # 11
[QUOTE = Berkay] By the way, Cecoli is my car's original tire size 195/55/15. Therefore, it will not cause any problems when it is worn in other 206's. My vehicle fenders etc. I guess it's the same as the other 206. Even my winter tires are 185/60/15. Gülme
I only know that Quics have 195 55 15. I don't think they put it like that. When I got the 2.0 138bg GTI 185 55 15, I couldn't give quic in 195 sense. Also don't you know it different from your fenders' others ???
The fenders of Quic, GTI and RC are more tight.
The best tire to be in Quic exortion 206 is 185 55 15 or 195 50 15 truck ...
08.05.2020 16:05 # 12
murat deniz
cem machine's battery is dead I could not take a photo, but I write everything on the sticker I wrote. There is tire pressure at the top 2.3 bar "175 65 14 R 14 T" written below it, tire brands are written below these values. at the bottom, there are the following numbers that I don't understand: 0995681 and 20551.
[QUOTE = CeCoLi] Can you first write the original tire size ??? 175 65 14 ???
08.05.2020 16:05 # 13
God, did you miss the issue of offset ??? I persistently want to see the striker. Charge the water machine side Sırıtma
Okay, what did I say to you anyway ??? I should have written 175 65 14. All the information needed is already above ...
08.05.2020 16:05 # 14
alihan59
What is the meat ratio? I have a steel rim on top of it. There are all kinds of them, they were 195 to 65 15 what was everything I will take fifteen 52 for the summer, but there is a meat event or something, I am looking for them. alihan59 2015-12-02 20:34:49
08.05.2020 16:05 # 15
samet206
ET Values are 20-25 for peugeot. For peugeot 4x108, so there is not much choice. The wheels in this wheel spacing generally do not need to be attached to peugeot or ford. It is not appropriate, you should use 50 max 55 as a cheek on the tires. I would like to see the original models in terms of wheels, the difference is good, but being permanent is something else.
08.05.2020 16:05 # 16
alihan59
I'm knocking on the muddy or I'm going to eat the head and pull the car to the ground. Fifteen size 7.0x20 15 inches at 6.5x30. alihan59 2015-12-03 16:17:07
08.05.2020 16:05 # 17
samet206
I know that ET 35 is a peugeot peer, if you install rims with incompatible ET values, rubbing is inevitable.
08.05.2020 16:05 # 18
Htc
Is the original tire size 175/65/14 for Mrb's 2001 model 206 xr?
08.05.2020 16:05 # 19
Ozdemir35
My friend has 14 Wheels of size 206 175-185. Install 14 or 15 wheels without you, but don't wear tires of size 185 or above, it will tire the car and burn too much fuel.
