Wheel and tire recommendation for 206 x- desing
08.05.2020 14:04 # 1
umuttar
2006 206 x- desing im war. tires are life for you now. Cry I want to get it on the tire with wheels. be both images and safe ..
I replaced the entire braking system. all I have is rubber left.
and then the angel headlights war. just before the exhaust :) LOL
08.05.2020 14:04 # 2
deniz_206
If the master had introduced himself to the forum, but whatever the vehicle is, the xdesing 1400 engine does not pull the tire with a very high size, it will tire the vehicle very much and it will increase in the fuel.
08.05.2020 14:04 # 3
it would be better if you introduce yourself first
08.05.2020 14:04 # 4
deniz_206
I said it too, buddy introduces it soon.
08.05.2020 14:04 # 5
umuttar
I introduced myself but I am here again
I am umut
I'm sitting in hunters 206 x desing im war
I work as a molding chief in an aluminum firm
08.05.2020 14:04 # 6
umuttar
thank you for tawsiye
08.05.2020 14:04 # 7
Each 5-spoke wheel would be :)
08.05.2020 14:04 # 8
umuttar
get some shape :)
though I am thinking of buying 207 or lancer evo, but let's handle it with a tire.
08.05.2020 14:04 # 9
H-a-d-i
if you are going to change the vehicle, get it done before it gets too expensive. Bridgestone B330 EVO 175/65/14 rubber tires 97 TL.
Kumho if it was expensive.
If fuel is more important than the image, take the 14 "rim that fits in your pocket.
08.05.2020 14:04 # 10
t@lip
If you put 185/65/14 instead of 175/65/14 for 206 what would be its advantages and disadvantages, friends, I would appreciate if it illuminates, thanks
08.05.2020 14:04 # 11
H-a-d-i
Numbers 175 and 185 are the tread width of the tire. the narrower, the less it burns, but the less friction will also reduce the grip. If the base is wide, the fuel increases, the engine gets tired and the friction area increases, so the tossing in the bends decreases.
the original dimensions of the vehicle should not be exceeded as much as possible. but I think there will be no noticeable difference between 175 and 185. It looks more sporty in terms of 185 images.
08.05.2020 14:04 # 12
umuttar
[QUOTE = hderelli] if you are going to change the car, get it done before it gets too expensive. Bridgestone B330 EVO 175/65/14 rubber tires 97 TL.
I found a 185mm tire, they say 199 lira with 100 lira rims and they enter my head
I will not sell the car, it will eventually be
08.05.2020 14:04 # 13
H-a-d-i
If the wheel of my car is new, I wouldn't stop buying a new car. If you won't ride for a long time, just buy a tire. if the wheel covers are too old, you can only replace the covers. 4 covers are between 35-50 TL.
08.05.2020 14:04 # 14
umuttar
[QUOTE = hderelli] If my car's wheel is new, I wouldn't stop buying a new car. If you won't ride for a long time, just buy a tire. if the wheel covers are too old, you can only replace the covers. 4 covers are between 35-50 TL. [/ QUOTE]
I love my car so much but now it has exceeded 100000 I bought a 2008 polo in my wife last year its installments are over now now bnm car war
I do not need to tell 206 is still a legend for us
now in my head that war 207
I still do not want to pay a bank installment for a while.
But when the car is under me, he'll give me the right to be on the road.
08.05.2020 14:04 # 15
t@lip
[QUOTE = hderelli] The numbers 175 and 185 are the tread width of the tire. the narrower, the less it burns, but the less friction will also reduce the grip. If the base is wide, the fuel increases, the engine gets tired and the friction area increases, so the tossing in the bends decreases.
Thank you very much for the answer, it is an interesting situation, but in my car, the fronts are 185, the backs are 175. The man I bought wore the fronts 185 and the front tires are new compared to the rear tires, the arcs need to change in the short term. In this case, I can easily replace the old 175 tires with 185.
08.05.2020 14:04 # 16
H-a-d-i
then it seems logical to get 185 behind. make sure it looks more beautiful
08.05.2020 14:04 # 17
berko
buy the cleanest 17 rims for you 207 nor do you wear
08.05.2020 14:04 # 18
195/45/16 4x108 you will never have a problem, it has been tried personally.
08.05.2020 14:04 # 19
Ozgur
185/55/15 ... 206 is the most suitable tire for diesel. It does not matter 0.5% in terms of fuel. With this tire, in terms of fuel etc ... there is a very little decrease in the final speed. You cannot understand the difference in acceleration.
08.05.2020 14:04 # 20
MirakGTI
I used 206 hdi vehicles, I fitted 16 inch rc wheels and 205 45 tires.
there was a bit of difference on departure but I think the value for the image
Page : / 2
