wheel air pressure
08.05.2020 17:07 # 1
sert-ac
friends, I use the tool in my signature. I said let me look at the sole and let me hit the wheels and they'd be 25 out of it.
I am using a Michelin brand, I do not know the exact size of the wheel, but the standard is used in my vehicle mode.
08.05.2020 17:07 # 2
sert-ac
Also, there is no warning mechanism in the tire pressure dust on my friends car? 25 low cunk because it didn't mean it was okay ... but I know it should be
08.05.2020 17:07 # 3
hsnsnl
the tires have 195 "wheels and 15" wheels. You have to press 30-31 in front and back.
08.05.2020 17:07 # 4
MagicPerformance
30-32 is ideal. Also, there is no measure called 195/65/91 :)
08.05.2020 17:07 # 5
sert-ac
http://www.sahibinden.com/ilan/vasita-otomobil-peugeot-2006-peugeot-307-1-6-hdi-premium-110-bg-ilk-el-98251219/detay/ my vehicle is the same model year I have the same rim as the wheel
1-do not have to warn dust
between 2 and 30 32 so it is the difference, am I supposed that I pressed 30 and back
08.05.2020 17:07 # 6
MagicPerformance
30 is ideal.
08.05.2020 17:07 # 7
sert-ac
I didn't look at it, I came and I came on it says 205-55-16 and it does not use 16.5 rims in the eng side, I think it is 16 inc sert-aç 2012-11-01 00:43:20
08.05.2020 17:07 # 8
tellotello
Your vehicle has a 16-inch rim, normally I think it says 205/55 R16. In my car, the 195/65 R15 writes, each of the dimensions here has a meaning. It refers to the rim diameter after the last R. I am printing 32, but when I hear the signal that it is already 32, I am printing 31 or so if we consider the air escaping while shooting. He offered me a master, but I did not expect scientific explanations from the man (he said something, but you ended up with the bass). ). The vehicle in the link is one of the fullest models but I don't think it has it either. I know that there is a lamp on the front panel if your car has tire pressure control. & Nbsp;
08.05.2020 17:07 # 9
sert-ac
[QUOTE = tellotello] Your vehicle has a 16-inch rim, normally I think it says 205/55 R16. In my car, the 195/65 R15 writes, each of the dimensions here has a meaning. It refers to the rim diameter after the last R. I am printing 32, but when I hear the signal that it is already 32, I am printing 31 or so if we consider the air escaping while shooting. He offered me a master, but I did not expect scientific explanations from the man (something said, but you ended up with the bass). "Smile"). The vehicle in the link is one of the fullest models but I don't think it has it either. I know that there is a lamp on the front panel if your vehicle has a tire pressure control. [/ QUOTE]
Thanks for my information, my vehicle is the same as the one in my signature and it is the same as the vehicle, but I don't have a warning system. I push
08.05.2020 17:07 # 10
bestoforhan
When peugeot cars open the left front door & nbsp; there are tire pressure values inside. but the values are entered as bars. we use psi & nbsp; pressure value. For this, we multiply the bar value of your vehicle by 14.5 and find the psi value. & nbsp;
for example, it writes 2.5 bars in my 407 & nbsp; 2.5 * 14.5 = 36
