Whatever I did, the vehicle still pulls to the right ??
08.05.2020 15:27 # 1
mdincer34
I went to the long road with my friends 307, I bought two zeros michelin in front of the place where I went with the complaint of pulling the car right. 195 65 15
tie rod was balanced
front tool zero
I looked at the brake discs, but the vehicle still pulls to the right, and the steering wheel is shaking, the balance seems to be out of balance, for whatever reason the vehicle pulls to the right, by the way, even before reaching high speed, the vehicle pulls to the right.
08.05.2020 15:27 # 2
metin
Did you check the rear tires?
Also, the ball balance cannot do well for everyone.
08.05.2020 15:27 # 3
mdincer34
I put the best tires in the back, I know the wrong tires, I know it is wrong, I said the tire while buying the tire, we put the old tires with the best teeth on the back.
08.05.2020 15:27 # 4
CAN IT BE A RIM AT THE WHEEL RIM?
ALSO RELIEF ON THE ROT BALANCE EVENT I HAVE MADE A NEW SUB TEAM AND THE ROT BALANCE IS ADJUSTED, BUT IT IS STEERING TO THE STEAM OF 100 KM .
08.05.2020 15:27 # 5
mdincer34
I couldn't solve it anyway, they are getting the problem, they do not understand or the rot has been balanced twice.
08.05.2020 15:27 # 6
sedatdatse
I bought 4 michelin tires 1 month ago and they made rot balance free
and when I was going to Kastamonu, I was flickering at high speed and I entered the tire at the turn and there was a 2 mm difference in the rods
08.05.2020 15:27 # 7
mdincer34
yes i guess the problem is rot balancing find a good master was done twice the problem is still going on the problem of excessive shaking and pulling to the right continues the vehicle is also vibrating like a steering wheel phone in 130
08.05.2020 15:27 # 8
sedatdatse
You feel after 90,
08.05.2020 15:27 # 9
Haksen016
From the master to the master, as far as I understand, you have done all the controls, but if it still pulls, there is no problem with the steering.
08.05.2020 15:27 # 10
the same problem was with me ...
Do not forget to have the imbalances in the back torsions set up.
Don't think it is related to the front of the car .. I thought so for months. The problem came out of the rear torsions now it has improved :)
08.05.2020 15:27 # 11
metin
[QUOTE = facemelowe] same problem was with me ...
yes it makes very sense. the result is that you can pull the vehicle back and forth on the rear wheel
08.05.2020 15:27 # 12
mdincer34
I think there will be costly bits for adjusting the rear torsion or changing parts :(
08.05.2020 15:27 # 13
mdincer34
friends today, all balance rot front team went to the control, there was nothing in balance in the vehicle, but the light flickering at high speed at the speed of the car flickering was set as a firen disk with the master, firen discs flickering yes maybe but it could cause the vehicle to pull to the right.
08.05.2020 15:27 # 14
metin
[QUOTE = mdincer34] friends today I went to the whole balance rot front team control again, the car did not come out of balance, but the light flickering at high speed, the steering wheel is shaking, the master was detected as a firen disc. ]
If the brakes are pressurized, if one side is holding more than the other, it does not pull when driving on the road. Of course, if the brakes are not adjusted, it also brakes when driving on the road.
08.05.2020 15:27 # 15
ose
If the brake presses, there is a relationship. No, I don't know if it pulls without pressing. Have you looked at the four wheels and did the brake have a tight wheel while the vehicle was on the lift?
08.05.2020 15:27 # 16
mdincer34
hmmm we did not rotate all four wheels idle, if there is braking on one wheel, it will pull to the side and it will be good if i put it on my solution list
08.05.2020 15:27 # 17
revolutionary26
I had a palio vehicle. the front right brake shoe was squeezing but it was not noticeable, the vehicle was pulling to the right all the time, while the motion was on the helm .. it started to hang well after the blower was over.
08.05.2020 15:27 # 18
mdincer34
hmm yeah yeah, if I find a solution, I'll share it here. Keep the ball joint balance.
08.05.2020 15:27 # 19
metin
[QUOTE = mdincer34] hmm yeah yeah if I find a solution I will share here already hold the tie rod balance, the front tire has changed completely when it comes to tires:) [/ QUOTE]
It seems to me that it is probably like brakes because we ignore the knees linings, especially when we come in a certain way with the vehicle, we wash the vehicle before the discs cool down, and the discs are distorted, rubbing against the linings, braking the vehicle.
By the way, mdincer34 has been renewed in the front team.
text 2011-05-24 21:50:47
08.05.2020 15:27 # 20
ose
If your balance is complete and achieved, you should also check the back of the discs that will go to bad correction. kankam_743 2011-05-24 22:10:49
Page : / 4
