What To Do When Visiting A Visa?
08.05.2020 20:57 # 1
Brcbyrktr
Good Evening Friends ..
I will be entering the vehicle visa for the first time in August. I am afraid of exhaust emissions. I have a problem with fat burning and Black smoke. I have trouble because I can't afford it. Apart from this, I want information and thio from mates that have been on visa recently, in terms of matters, transactions and costs. Thank you to the interested friends.
08.05.2020 20:57 # 2
maximusti
wheel sizes on the same axle will be the same
have the rod rods checked,
xenon in headlights, led does not pass, original halogen should be
your horn needs to work,
handbrake, wipers and seat belts are checked,
There is not a very dark film on the windows,
If you are afraid of exhaust emissions, you can have an emission test somewhere before the inspection is not very expensive (two years ago).
If you take a value that will not exceed, you will at least see it all over again.
08.05.2020 20:57 # 3
AydinBeyol
Buy a würth injector cleaner before going to the exhaust death.
08.05.2020 20:57 # 4
doganatak
Do not have the exhaust at the inspection station.
I'm telling you, because it happened to me, be sure to look at the brakes if you have a deviation in the brakes. Me and my friend were left for this reason.
One of my friends also stayed in his problem, he put the tire upside down, so there is an arrow on the tire, he was looking at the opposite side, be careful because I saw it for the first time.
08.05.2020 20:57 # 5
x571
Friends using LPG. Look for any changes since the last inspection. go to get things done.
08.05.2020 20:57 # 6
talip206
[QUOTE = x571] friends using lpg. Look for any changes since the last inspection. go to get things done. [/ QUOTE]
If there was a plastic spiral protection on the LPG pipes from the tank passing under the vehicle to the engine last year, it remained unexamined. The pipes would be open. They removed it again this year. Now it is passing.
There should be insulation material under the tank. (They don't look at the bagels because they already have foam)
If you stay under inspection due to lpg, it is necessary to get a sealing report.
talip206 2018-07-14 17:13:00
08.05.2020 20:57 # 7
talip206
also
The plate is important if you have any screws or screw holes on your plate, you will be excluded from the examination. If there is a screw, unscrew the holes, etc. Close with things.
talip206 2018-07-14 17:08:55
08.05.2020 20:57 # 8
x571
[QUOTE = talip206] [QUOTE = x571] friends using lpg. Look for any changes since the last inspection. go to get things done. [/ QUOTE]
What is this? I stayed with him last year. whereas they wanted that spiral in the year we built it. Now we are going to have a spiral again when we go to the examination.
08.05.2020 20:57 # 9
talip206
[QUOTE = x571] [QUOTE = talip206] [QUOTE = x571] friends using lpg. Look for any changes since the last inspection. go to get things done. [/ QUOTE]
Well, I went both for filter replacement and for spiraling. No need to disassemble the dealer, they are not looking anymore, he said. I don't know if they want spiral again.
08.05.2020 20:57 # 10
x571
[QUOTE = talip206] [QUOTE = x571] [QUOTE = talip206] [QUOTE = x571] friends using lpg. Look for any changes since the last inspection. go to get things done. [/ QUOTE]
it wouldn't be so fair. I did not know last year, I went.I remained from it.I removed the spiral and gave the money for a sealing report of 250 TL. a bad inspection blew me for 500 tl.
