What size tire do you have in 106?
08.05.2020 16:34 # 1
ozdemirosman
friends, 2001 quik e 185 65 14 tires I had 3 months no problem, but now when a person sits in the back, the rear tires rub against the hoods I took it from the torsion, I said it made me feel like a shock absorber, but the 2 different masters are solid & nbsp; I think it is unreasonable because these tires are 3 months without trouble and the width that I raised but the part that rubbed in the hood was 11 wool and the part near the middle of the tire. I will solve this problem, I spent 570 TL, not solved die there is no return I will not sell this car like this. I am looking at the nation's vehicle. They wear 195 tires. why?
08.05.2020 16:34 # 2
djchaos
If it has been dropped from torsions, the vehicle will rub and after it has been removed, it may be installed low when torsions are installed. % = 106-Saxon-torsion-alaltma- my ddle # 288398
08.05.2020 16:34 # 3
KenBlockJR
the size is too big. original size is 165/65/14.
185/55/14 and 195/45/15 are also equivalent in diameter. You can't use it outside of these 3 sizes.
The diameter of your tire and the big friction around it is normal
08.05.2020 16:34 # 4
ozdemirosman
I do not think that the size of the tire is large; According to this document, the certificate of conformity of my vehicle is still available. Tires of size 165 * 70 * 14,165 * 65 * 14,175 * 60 * 14 can be used. The tire in me is 185 * 65 * 14 but there is no problem in the tread of the tire. There is no problem.If the cheek seems to be troubled, I have a tire that is only half a cm higher than the tire that is suitable for this vehicle, and (I underline) the rubbing problem is not a half a cm problem. tires are not newly installed this month will be 4 months, these tires are installed and there is this problem for 1 month.Although it is not possible to adjust incorrectly and rub because of the torsion repair is done after rubbing. Thank you for the answers you wrote.
08.05.2020 16:34 # 5
Ego_Ist
185-55-14 and also 4mm spring, no problem
08.05.2020 16:34 # 6
okankrgz
I use 14-55-185 tire size. At 106 m, I think it would be more useful if you add a photo of your vehicle from the front.
08.05.2020 16:34 # 7
ozdemirosman
I will add as soon as possible
08.05.2020 16:34 # 8
KenBlockJR
[QUOTE = ozdemirosman] I do not think that the size of the tire is big; According to this document, the certificate of conformity of my vehicle is still available. Tires of size 165 * 70 * 14,165 * 65 * 14,175 * 60 * 14 can be used. The tire in me is 185 * 65 * 14 but there is no problem in the tread of the tire. There is no problem.If the cheek seems to be troubled, I have a tire that is only half a cm higher than the tire that is suitable for this vehicle, and (I underline) the rubbing problem is not a half a cm problem. tires are not newly installed this month will be 4 months, these tires are installed and there is this problem for 1 month.Although it is not possible to adjust incorrectly and rub because of the torsion repair is done after rubbing. Thank you for the answers you wrote.
is wrong. the diameter of the tire grows as the base grows. & nbsp;
you can calculate here & nbsp; http://www.lastik24.com/calculation.aspx
08.05.2020 16:34 # 9
psychoabi
in my 106 I use 175-60-14
08.05.2020 16:34 # 10
kaderim@61
185/55/14 dunlop rubber 5cm spring, no matter how many people sit in the back, no problem :)
08.05.2020 16:34 # 11
aclern
185/60/14 and I also have dunlop rubber and 3.5 cm spring I have
08.05.2020 16:34 # 12
ozdemirosman
These were the tires I removed 3 months ago.
08.05.2020 16:34 # 13
ozdemirosman
I wonder if my friends wearing these bows can find them. If you help them, I would appreciate you for your time.
08.05.2020 16:34 # 14
ozdemirosman
First of all, thank you for your interest in the problem, but when the tires that come and go are written, it is 0.2 inches from the sidewall to be formed. i.e. & nbsp; It makes 0.5 cm. The problem is not half a cm problem. When a single person of 70 kg is at the rear, the sponge of the tire in a small spring is adorned in the middle section of the hood, which is connected to the rear bumper at 10 o'clock.
08.05.2020 16:34 # 15
ozdemirosman
If I buy sports bows and wear them, I wonder if I will go for a harder bow or replace my shock absorbers.
08.05.2020 16:34 # 16
ozdemirosman
actual
08.05.2020 16:34 # 17
kaderim@61
brothers, 185/55/14 106 gti, i mean the size of the org, i mean, they would not be the original if they would be in short words, i would not use the original i would be driving my car quik you have 65 cheeks if you take 55, the distance will be even more painful, so there will be no rubbing look, even if it is 60 cheeks, put 3 people in the back, but it will put 3 people on the back. 55 rubs on the cheek is reported by experience 185/55/14 you will be comfortable.
08.05.2020 16:34 # 18
kaderim@61
Also, there is no spring on the back, there is torsion on the back.
08.05.2020 16:34 # 19
minolta35
The dimensions such as 55-60-65-70 are the ratio of the height of the sidewall to the base. So the tire, which is called 185 * 65, has a sidewall height of 120 mm. According to the information you provide, 60 sidewalls are recommended even at the recommended max base 175.This makes 105 mm. There is only one possibility since you say that it does not rub for 3 months.
08.05.2020 16:34 # 20
ozdemirosman
"Thumbs
