What should we understand from the DYNO report
08.05.2020 16:23 # 1
Bavik
I would be glad if anybody explains what we should understand from the dyno test they put these tools, I put one picture at the bottom
08.05.2020 16:23 # 2
06OzGuR06
This graph shows the torque and power values obtained depending on the engine speed.
78.8 Kw power was obtained at 4865 rpm, which means 107 Hp power. (I.e. the power taken from the engine) The speed of the vehicle is 133 km / h
Net & nbsp; 59.5 Kw & nbsp; about 80 HP means power.
The vehicle has reached a speed of 148.4 km / h at a maximum of 5415 rpm. torque is measured at 159.5 Nm.
In short, the engine of the vehicle generates a certain power.This power is lost due to friction in the driveline such as transmission and differential. These tests allow us to understand whether the vehicle's gearbox or other driveline is worn. The same applies to the engine.
These values differ in gasoline and diesel engines.
What is the brand and model of the vehicle?
adventure peugeot 2011-11-22 00:02:43
08.05.2020 16:23 # 3
Bavik
Is the 406 sv normal or are these values lower than they should be? by the way, thanks for your clarification :)
08.05.2020 16:23 # 4
Ucyuzalti
Not less than 150 km & nbsp; Don't your vehicle exceed 150 km now? & nbsp;
08.05.2020 16:23 # 5
06OzGuR06
. 406 1.8 ST 406 2.0 SV 406 3.0 SV Engine Volume (cc) 1762 1998 2950 Number of Cylinders 4 4 V6 Horsepower (BG / d / d) 112/5500 135/5500 194/5500 Highest Torque (Nm) / (d / d) 155/4250 180/4200 267/4000 Final Speed (km / h) 192 203 230 0-100 km / h Acceleration (sec) 12.5 11.0 8.2 Fuel consumption (at 100 km) at 90 km / h (liter) 5.4 6.1 8.0 At 120 km / h (liter) - - - In the city (liter) 10.1 11.3 15.9 Weight (kg) 1275 1315 1455 Wheelbase (mm) 2700 2700 2700 Length (mm) 4555 4555 4555 Width (mm) 1765 1765 1765 Height (mm) 1396 1396 1396 Luggage Volume (liter) 430 430 430 If we evaluate according to the technical data, there is a decrease according to the original values. Of course, this varies according to the mileage of the vehicle. Of course, there is no such thing as engine power will always remain the same.There are certain decreases in power due to the parts that wear out over time. Of course, these values are valid for gasoline, if your vehicle entered the test with LPG, so different results may have been obtained. 06ÖZGÜR062011-11-24 16:04:37
08.05.2020 16:23 # 6
Bavik
The tool is already tested with lpg, but this test & nbsp; They got this data in 3rd gear when he got in, how do I know if the engine wants to advertise & nbsp;
08.05.2020 16:23 # 7
06OzGuR06
What is the km of the vehicle?
08.05.2020 16:23 # 8
Bavik
It was said that there was no need for heavy maintenance in 195000 but 1.5 years ago & nbsp;
08.05.2020 16:23 # 9
06OzGuR06
I think there is no need for revision, this km and these values are normal, I think there is also LPG. There is a decrease in the torque and power values of the engine.
08.05.2020 16:23 # 10
Bavik
Even if there is a little oil, I do not have any problems in the valves in the fuel or thanks for informing.
