What should the 301 ideal cycle range be?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:47 # 1
mrmaden
I bought a 2017 active package. I asked him if he was looking for the ideal cycle when I bought it. The sales consultant said 2500-3000. However, when I drive with the vehicle, it gives an upper gear shift warning while traveling in the 1200-1500 rpm range. Likewise, I have the sound of the engine in that speed range and I feel that I need to shift to top gear in the 1200-1500 range. Do you think I should focus on 2500-3000e or act according to the command given by the vehicle's screen.
08.05.2020 20:47 # 2
HasGur
[QUOTE = mrmaden] I bought 2017 active package. I asked him if he was looking for the ideal cycle when I bought it. The sales consultant said 2500-3000. However, when I drive with the vehicle, it gives an upper gear shift warning while traveling in the 1200-1500 rpm range. Likewise, I have the sound of the engine in that speed range and I feel that I need to shift to top gear in the 1200-1500 range. Do you think I should focus myself on 2500-3000e or act according to the command given by the vehicle's screen. [/ QUOTE]
If some road conditions change the situation, and if the vehicle speed after the maximization or reduction decreases / rises to the torque produced , you will get the best performance with the lowest fuel consumption .
Hasgör 2018-03-04 14:50:42
08.05.2020 20:47 # 3
boruc
[QUOTE = HasGur] [QUOTE = mrmaden] I bought 2017 active package. I asked him if he was looking for the ideal cycle when I bought it. The sales consultant said 2500-3000. However, when I drive with the vehicle, it gives an upper gear shift warning while traveling in the 1200-1500 rpm range. Likewise, I have the sound of the engine in that speed range and I feel that I need to shift to top gear in the 1200-1500 range. Do you think I should focus myself on 2500-3000e or act according to the command given by the vehicle's screen. [/ QUOTE]
Some road conditions change the situation, but v ites if the vehicle speed after maximization or reduction decreases / increases the max torque to the generated speed en with low fuel consumption you get the best performance.
While diesel engines max torque at lower rpm, gasoline vehicles max torque at higher rpm.
e.g
206 1.4 hdi 1750d / min
206 1.6 achieves max torque at 110hp 3900d / min
In this case, can we say that diesel vehicles should be used at low speed and gasoline vehicles should be used at high speed?
08.05.2020 20:47 # 4
HasGur
[QUOTE = borucu]
e.g
In this case, can we say that diesel vehicles should be used at low speed and gasoline vehicles should be used at high speed? [/ QUOTE]
Although it is necessary to take advantage of the maximum torque by going to high speed in road / usage conditions such as long-distance or loaded ramp climbing with 1.6 110 vehicles. Each engine has its own characteristic. For example, the VW 1.4 TSI gasoline engine reaches max torque at 1500 rpm, while the same brand 1.6 FSI gasoline engine produces max torque at 3800 rpm, similar to the pug 206. High speed causes more fuel consumption. In order to determine the most appropriate vehicle use, it is necessary to evaluate according to the road conditions in accordance with the manufacturer's data.
