What Should I Change My Vehicle For Maintenance?
08.05.2020 18:25 # 1
Mbiwa
My car 206 1.6 8v Gasoline + 2001 model with LPG. 160 thousand km maintenance will come after 3 thousand km. What do I need to change first, friends, I think it is not enough to say skillful oil pollen filters?
08.05.2020 18:25 # 2
oguzhan29
In normal maintenance, oil and filters change, routine checks are done, spark plug condition etc. like
08.05.2020 18:25 # 3
Mbiwa
I don't know when they changed the timing apricot.
08.05.2020 18:25 # 4
outlaw
THE CHANGE IS DEPENDING ON YOUR BUDGET, IF YOU HAVE THE OPPORTUNITY, DO AS I DO.
WHEN CHANGING TIRIGER I HAVE REPLACED THE PRINT
BRAKE PADS DISCLER BRAKE CENTER PUMPS ..
If it is not, you will never mind.
08.05.2020 18:25 # 5
C@GL@R
Prepare 1500 pounds if you will get into this vehicle ..
08.05.2020 18:25 # 6
Mbiwa
I had an average price of 500 TL, not 1500, in my head
08.05.2020 18:25 # 7
kuscu38
*oil
*oil filter
*air filter
* if it is 10.000 km with a replacement or a plug-in gas filter (definitely replace it, otherwise both fuel will increase and problems with syringes will occur)
* transmission oil (if it's 20,000 km, the room is arbitrary, but be sure it feels feel good.)
*spark plug
* spark plug cables
* POLEN FILTER ( we are entering the summer air conditioned probably your vehicle)
* Have the air conditioner gas checked (especially if you do not need to go to the air conditioner, it is also with the gas in the refrigerator cabinet)
* Keyfe sorrow complete paste polish
* Take 4 pads of sprays when you put your car in maintenance, when you lift it under the fiber, clean the bottom and top of the engine completely, 5 lira in your vehicle, there is nothing called oil makes the engine like a cillop :)
those that come to my mind, if these are my cons, I would be happy if the friends complete ....
08.05.2020 18:25 # 8
Mbiwa
Thank kuscu38
08.05.2020 18:25 # 9
iso307
In addition, have the rod ends and ball joints checked.
