What should be the 206cc wheel bar?
08.05.2020 20:20 # 1
spade
friends I have a little question;
What should be the bar setting of the front and rear wheels?
On the driver's seat it writes 2.3 for the front and back. If it is installed, it says "3.0".
When I ask friends who understand the vehicle; "Bar 3.0 is not set off with a wheel," they say. What is the truth of this job?
08.05.2020 20:20 # 2
2.3 * 14.50326 = 33.35 psi, so if you press 34 psi enough bro 3 bars of the press are rubber benefits every week of our turkey the way I usually I press 34 to the front always 175/65/14 brake mesafa way Tutsis and fuel consumption bay with a difference It saves.
08.05.2020 20:20 # 3
Oktkor
Listen to friends who understand the vehicle, the engineers of the men who produce cars will not know. :)
08.05.2020 20:20 # 4
talip206
In our country, there is generally a low tendency to press. Usually 30 to 31 people are printing. Last summer I was pushing 32 on the tires, someone came and said. Have you ever printed 32 tires, the weather is hot long road tires boom I am a tire guy said he won't print that much
The guys know better than the engineers who made the car. In addition, tire manufacturers do not recommend low pressure for tire life and road safety.
Soner is as good as 33 34 about his friend. talip206 2017-05-10 19:55:38
08.05.2020 20:20 # 5
boruc
I have 195/50 / R15 tires. I print 33 psi. Is Uyguner?
Tool 206.
08.05.2020 20:20 # 6
OguzhanKucuk61
I press front 34 rear 32. When the vehicle is unladen. If there are 2-3 passengers in the back and full of luggage, I am printing around 36.
There are those who say the front should be the same, but I do something like this because I do not count the weight of the front of the vehicle the same. Is it true ?
08.05.2020 20:20 # 7
[QUOTE = OguzhanKucuk61] I am pressing front 34 back 32. When the vehicle is unladen. If there are 2-3 passengers in the back and full of luggage, I am printing around 36.
There are those who say the front should be the same, but I do something like this because I do not count the weight of the front of the vehicle the same. Is it true? [/ QUOTE]
There is no problem. Oğuzhan tire pressure values like you in my new vehicles have my friend 2015 i20, they have pressed 34 in the front and 32 in the back. or latic pressure indicator says it is flashing :) I got the summer houses on the weekend.
08.05.2020 20:20 # 8
OguzhanKucuk61
[QUOTE = sonerkyl] [QUOTE = OguzhanKucuk61] I press front 34 rear 32. When the vehicle is unladen. If there are 2-3 passengers in the back and full of luggage, I am printing around 36.
Thank you, Soner. We need to be conscious as a society.
I do pressure control every 1-2 weeks. I have a pen that I am sure is correct. The friend says, why do you constantly check, my father "even" just looks at the long road. In his eyes, his father is a master driver :))
08.05.2020 20:20 # 9
you are doing the most correct, i check every time i get fuel, general 1-2 psi decreases i complete the pressure.
