WHAT SHOULD BE CONSIDERED WHEN TAKING A SECOND CAR?
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 17:32 # 1
Memed8572
Surely we have all set off for a second-hand vehicle so far. There are some things that everyone knows more or less when buying a vehicle. If we put these known ones into a list, it is just as follows. One item in your mind may be useful for you one day. I wish you good reading. - Take care of buying a car from the owner. - Go to the car in the daytime, if possible, notify at the last minute. - Do not go alone to pick up the vehicle. - Check the engine and chassis numbers with a license. Try to understand if it has changed. - Look at the car's brake, gear knob and steering wheel. It should not be worn. I think it's more important than the mileage of the vehicle. Especially in hard vehicles, the brake is very crushed. - Check the door and bonnet depths to see if the vehicle is in its original color. - Learn the profession of the car owner. The richer, the more money he has to look after the vehicle. Be careful not to be young. - Check the gap between the bodywork parts, the headlight gap, and check whether it is smooth. - Check under the vehicle. Check for catalyst cancellation. (Catalyst prices average 750 + TL) - Check all equipment one by one. (ABS and airbag are very important) - Open the bonnet, check for oil leaks. - Look at the car from a distance on flat ground. Check your balance. - Operate the vehicle at idle speed when it is cold. Irregular idle indicates unhealthy or neglected engine. - Buy a vehicle with heavy maintenance time or check that it has been done in the service. In any case, it would be better for you to do it yourself. Otherwise, it can cause much more costs. - Check engine belts and water. Hold the vehicle steady, check for leaks at the bottom. - With plastic magnets, you can understand the state of the paste in the bodywork. - Check the tires of the vehicle, 4 tires can reach 1000 TL. - Have mileage, bodywork and compression tests at the vehicle's own service. - Evaluate the paint condition of the vehicle by age. - If you can, put it into the dyno test, remember that up to 10% loss is normal. - Check gear shifts. Check for a strain or a malfunction. - Engage 1st gear, apply the parking brake. Try to go slowly. If it does, the parking brake is problematic. - Shift into 4th gear. Try to lift the vehicle by giving a lot of gas. If the engine does not stop, the condition of the pressure pad is bad. - Do not buy vehicles with bad links or unbalanced because they may be hiding other problems by making excuses for their disorder. - Check the body and brake balances by leaving the steering wheel and braking on a flat road. - If you are a good enough driver, just stay in the car and try 0-100. Over 10% loss by age is not normal. - If the vehicle is winking at you, use it for at least half an hour. Turn off the music and pay attention to the sounds coming from the vehicle while using it. Remember, the dealer can show you the bad car with a few tricks, but these sounds will give you the car. - Drive quickly on the rough road. Check the sounds from the vehicle. - If the owner of the car does not get upset, give up, the market is full of cars, then do not regret. - If the price of the vehicle is cheaper than the market, you will need to pay much more attention. - When buying the vehicle, clean paper, OGS debt etc. The queries. - When purchasing the vehicle, park it in a neutral car park before paying the money. - Request a spare key. - Give the money at the notary when signing the contract, do not give it early.
08.05.2020 17:32 # 2
samet206
It is not possible to do most of these things nowadays, it is a fact that if you try to do it, you cannot buy a car and even if you come across the hair, you will be fired & nbsp; there is no need to exaggerate so we know that we are buying a second hand vehicle & nbsp; Necessary personal checks are carried out in one place, they are also shown to the master. Most of these items are related to forcing the vehicle & nbsp; In a way, nobody will force your car to anyone.
For example, if I sell my car personally, I am not responsible for the people going through the broken road quickly, if I go without buying it, who will take the responsibility of this if the faults occur in my vehicle. some of these rules are unreasonable and some are useful. .
Be careful not to be too young in this prejudice. What young people do not look at as much as the men who say wrong with me. It should be evaluated according to his man. Reviews
08.05.2020 17:32 # 3
cansytnn
Memed8572 I think you are very right. We bought 2 and a half months ago, 2006 model 1.6 hdi comfort 307, my father almost bought it and bought more than 2 thousand of them from the gallery. I think we have spent a lot of things that need to be considered, whether there is a car in the market or the man selling the mother makes a hair, if you say it does not sell or not, is there any other car out there?
08.05.2020 17:32 # 4
samet206
[QUOTE = cansytnn] Memed8572 I think you are very right, I bought 2 and a half months ago 2006 model 1.6 hdi comfort 307, my father bought it almost without looking and spent more than 2 thousand of the man bought it. I think that we spent 1500 TL extra for the month and I think these are the things that need to be paid attention. If there is no car in the market, the man who sells his mother selling a hair will make it behave, or if he doesn't sell it, is there no other car out there? [/ QUOTE]
My brother once cut out the hope that the car doesn't come out of the gallery so smoothly & nbsp; Take care to buy a car from the owner, I did not object to those items, I agree with all of them until the end. If you take the beam, it's really hard. If you do not want to be stacked, you will be awake in all conditions. This is the same for everyone. samet206 2013-04-24 13:05:54
08.05.2020 17:32 # 5
sedataksu
Is it possible to find someone who will allow so much control? The owner of the car is worse than beating the man, especially if I do not know someone who will allow driving for half an hour. If you are indestructible, if the first or second owner can prove them and if he is a proper person, you can shop.
08.05.2020 17:32 # 6
samet206
[QUOTE = sedataxu] Is it possible to find someone who will allow so much control? The owner of the car is worse than beating the man, especially if I do not know someone who will allow driving for half an hour. If it is the first or second owner if you can prove it, if it can prove them and if it is a proper one, you can shop. gif "border =" 0 "alt =" Clap "title =" Clap "/>
08.05.2020 17:32 # 7
syn022
If you care about this much detail, you will go and get zero. The second hand comes from the car in the sound and becomes in the paint. If you already know from the car, you will more or less solve your situation. It is not a problem to take it to a master, but I will not use it for half an hour.
08.05.2020 17:32 # 8
xpyhre
Thanks for sharing, it would be convenient to go to take the car with someone who is competent to do these applications. There is some exaggerated information among the items, after all, you buy a second hand vehicle. The person who will sell the vehicle may get bored with these applications and stop selling the vehicle :)
08.05.2020 17:32 # 9
Memed8572
Now, friends can be divided into articles among themselves in these articles :)
For example, if you take the rule from young people, if you buy from that young person, you are definitely burned, car scrap, etc., of course, there is no question. But in general, if you look at the event, for example, these hawk young people use their cars very despicably, they don't care, they don't care, they use cheap gas. beware of the young people there actually. otherwise I am a young person, I take care of my car very well, I wipe it inside, I wash it so that there is no dust soil, I do not smoke inside it. please do not approach the prejudice :) but of course you may not be able to go fast on a bad road. And whether you are more cautious when buying a 15,000 car or when buying a 60,000 car. If you buy a more expensive second hand car, you will want to try all of the above items.
08.05.2020 17:32 # 10
tellotello
I feel young too, maybe I will not be able to sell my napcam car & nbsp; "LOL". Let's see the answer & nbsp; "Big.
In the meantime, joking aside, no need to apply all of the writings, how much attention can be paid, he wanted to say enough. In addition, I was surprised almost for the first time in such an article that the catalyst was mentioned & nbsp; "Smile". I think it will be empty in nearly 100 thousand vehicles. At least ask the owner and get detailed information about it, because then it is a really expensive piece.
08.05.2020 17:32 # 11
hsnsnl
I'll take care of it and give it to me. I will apply them to my vehicle.
08.05.2020 17:32 # 12
elsoberano
Actually, all of them are things to do, but when I think about it, now I am selling my car. Someone is coming out of the pit. /> & nbsp; then I think I'm saying & nbsp; "Angry" "Angry" & nbsp; people get bored. No matter how much we care & nbsp; 2. hand is pulling something as it trembles on the problem of vehicles & nbsp; "Unhappy" & nbsp;
